MS2/Extra pre-3.4.2 beta 2 released
To announce the release of "MS2/Extra Pre 3.4.2 beta 2" this follows "MS2/Extra Pre 3.4.2 beta 1"
Who should use this code?
Experienced users wanting to test the new features or users experiencing bugs fixed by this version. Especially the EDIS bugfix.
Who should not use this code?
New or casual users - please use the current release code instead - see the Downloads page linked above.
Main changes since 3.4.2 beta 2
Bug fixes:
Workaround possible gcc/binutils bug impacting EDIS.
Changed features:
Update CBR600RR even fire 4-cyl offset.
Minor/internal:
Rev-limiter tooltip.
http://www.msextra.com/downloads/dev/ms ... 4-2/beta2/
Be sure to read the RELEASE-NOTES.txt and README.txt. Especially note that "Not Synced" has been renamed to "Not RPM synced".
Upgrading users are advised to enable the "old baro calc" for backwards compatability.
The current TunerStudio (2.6.0 or later) is required.
Bug fixes:
Changed features:
Minor/internal:
Re: MS2/Extra pre-3.4.2 beta 2 released
I fixed up the download link.
Hi James.
Please could you check out the staged injection stuff..
All works except for duty based staging ( or at least I can't get it to function )
Been trying to set stage up so that at 80 or 85 duty that the second stage comes online.
Almost grenaded engine.
I've checked back to 3.4.0 release and doesn't work there either.
Kindest regards
Phoenix 3D
Kindest regards
Phoenix 3D
phoenix3d wrote:Hi James.
Will post msq. soon, on tablet at the moment no where near machine.
Thanks James.
Phoenix 3D
Thanks James.
Phoenix 3D
No tune or log posted, so I've proceeded to release 3.4.2.
Hi James.
Apologizes for the late reply.
Been trying to get the msq from the drag car for the staged (duty based) issue.
Owner has gone away for a while.
So I tested it on the bench with the standard (boot up) msq.
Staged injection using duty based does not want to engage the second channel (when using 2 injector channels)
As well as the second (banks) when in semi-sequential. (Running 1 simultaneous on both tests)
All other switch modes work only duty based doesn't .
Sorry I can't upload an msq from the car but tested with the std. msq with same results.
Hope this helps?
Kindest regards
Gordon.
Hope this helps?
Kindest regards
Gordon.
MSQ and MSL please.phoenix3d wrote:So I tested it on the bench with the standard (boot up) msq.
How can you have a 3.4.2 beta
http://www.msextra.com/downloads/dev/ms2extra/
& a 3.4.2 release?
MS2/Extra 3.4.2 release Firmware
& a 3.4.2 release?
Check the name of the beta. It's pre-3.4.2 which means it comes before the 3.4.2 release. And the 3.4.2 release superseded the beta.
Then this is the latest.jsmcortina wrote:No tune or log posted, so I've proceeded to release 3.4.2.
As Jean says, "pre" means before.
Jamesdictionary wrote: pre-
1. before in time, rank, order, position, etc: predate, pre-eminent, premeditation, prefrontal, preschool
Then provide the download link to the released version or start a new thread, since the pre-version is obsolete.
Configuration Management (CM) is a systems engineering process for establishing and maintaining consistency of a product's performance, functional, and physical attributes with its requirements, design, and operational information throughout its life.
The purpose of Software Configuration Management is to establish and maintain the integrity of the products of the software project throughout the project's software life cycle. Software Configuration Management involves identifying configuration items for the software project, controlling these configuration items and changes to them, and recording and reporting status and change activity for these configuration items.
It's here: http://www.msextra.com/forums/viewtopic ... 01&t=59349 and on the Downloads page with other 'release' firmware.
Hi James..
Apologies for the Super Delay..
But here goes, The MSQ and MSL for the Duty Cycle based Staging Issue we've been experiencing.
I have also uploaded some other MSL's of the staging that works with MAP based.
Note We have tried this with BATCH injection Staging as well as Semi-Sequential Staging, problem persists with both configurations.
Kindest Regards
Phoenix3D
Kindest Regards
Phoenix3D
Further MSL's
Please Not this is a setup on a uS with additional Injector and Spark Channels Add-ons.
Thank you
Thank you
Hi James..
As well could you please look at the possibility of working out something for the guys that are using Fast Idle valves AND Nitrous.
Worst case scenario would you kindly be able to make an option of having NOS stage 1 on WLED and NOS Stage 2 on Fidle (Literally swap the outputs.) this will allow the use of the idle valve with 1 Stage of NOS.. (While still having ALED available and floating around not doing anything.. That could be used as well)
I have done this for one specific install we had to do, but once again "another" version of Code that is fully customised and we would have to support individually..
THIS IS ALSO on a uSquirt.
Kindest Regards
Phoenix3D
Kindest Regards
Phoenix3D
All good here with 2 MS2E and EDIS8 early days but working nicely, probably my last FW update now as going over to MS3X soon with VAG logic coils and full seq inj thanks
TVR Chimaera V8 on MS2 & EDIS 8 soon to be MS3 on full seq & VAG coils
MS2/Extra pre-3.4.3 beta 1 now released which should address the staging issue.
Cool Thanks James..
We'll have a look see as soon as the vehicle comes back in to us..
We'll keep you informed!
