Logic spark wiring
Re: Logic spark wiring
It's in the manual.
I just downloaded the pdf and looked thru the Web manual and didn't see the diagrams in the ignition section. Am I missing something? I may just be hungry and tired but I didn't see it anywhere.
Brent Savage
life behind the zion curtain
90 audi RS2 20VTQ 6sp MS3, MSX COP and Sequential and now MAF
87 Scirocco 2.0 ABA 16v EIP tubular cast MSII COP
86 Audi 4K20VTQ MSII
90 Audi 90 sedan 3.6l DOHC V8TT (project car)
89 VW cabbie (bitch basket) 2.0 ABA Turbo MSII
Ok I found it in the base manual not the ms3x manual. I'm guessing the best way to go is not use the msx output and use the spark outs?
Brent Savage
Section 5.3.1.3 Logic spark outputs - FET driver method, p. 76 for the description, schematic on the next.
Are you using a MS3 or MS2? Do you have the MS3X card?
Yes I have the ms3x been running it several years with pnp drivers. But I started with ms1 on this car and skipped Ms2. Tried the Ms2 but due to difference in trigger setup I didn't actually get running until ms3
Brent Savage
Hi!
This thread has several options for circuits for the PNP booster, but I can't keep up with you
Can anyone please refer to at schematics that works, so I can order the right transistors? I run MS3X and want to use the vag coils. Planning to bulid a small external box to put the drivers inside.
-MS3X, (V3 PCB) 1.2 RC 1 firmware. Controlling a light modified Audi 1.8TQ AEB 20v engine with Holset HE221W turbo, 299.4 HP and 400Nm at the hubs in Dynapack.
I have PCBs if you want to buy one.eMTea wrote:Hi!
Will the MS3X board be updated with the TC4427 elements ?
That's entirely up to B&G, the nice people who actually own the design, and sell the assembled cards to the various distributors. There are a number of "opportunities for improvement" that have been noted over the past few years, and it's due for a rev2.mega_user wrote:Will the MS3X board be updated with the TC4427 elements ?
Is it possible to drive a BIP 373 ignition driver through TC4427 chip?
MS3X uses a similar output chip for ignition outputs and can drive the BIP chips.
Yes, the TC outputs can be used to drive a BIP.
Does anybody build and sell a PNP driver "external box" ready to wire in? Kind of a Quadspark style.
I will be using MS3X and Audi COPs (NGK U5014).
Thanks,
Luis Roberto
Thanks,
Luis Roberto
Get an MS3Pro instead of the 3X and you can use the VAG coils without an external driver boxmancusogti8v wrote:Does anybody build and sell a PNP driver "external box" ready to wire in? Kind of a Quadspark style.
Thanks,
Luis Roberto
Support the developers!
Excuse my ignorance...
Why will a MS3Pro will drive the coils and not a MS3X? (both directly)
Luis Roberto
Luis Roberto
prof315 wrote:Get an MS3Pro instead of the 3X and you can use the VAG coils without an external driver boxmancusogti8v wrote:Does anybody build and sell a PNP driver "external box" ready to wire in? Kind of a Quadspark style.
Thanks,
Luis Roberto
Because the MS3-Pro uses a different circuit and was designed to be able to drive these coils.mancusogti8v wrote:Excuse my ignorance...
Thanks for the explanation.
The problem I have is that I already have the MS3X (with Mapdaddy and knock control).
So the alternative is via external box.. I can solder and follow wiring diagrams, but building a circuit...(as of now beyond my abilities).
Luis Roberto
Luis Roberto
jsmcortina wrote:Because the MS3-Pro uses a different circuit and was designed to be able to drive these coils.mancusogti8v wrote:Excuse my ignorance...
Go with the TC4427. There really is no circuit building, just one 8-pin IC and two resistors per two channels. Take a look at section 5.3.1.3 of the MS3 manual; the actual diagram is on the following page.
Let me see:
I buy some stripboard, 15 ohms 1/4 resistors then
http://www.digikey.com/product-detail/e ... -ND/418665
And then build this (attached image)
