True Flex Fuel Support
Is there a reason that flex fuel on MS2 isn't set up to interpolate between two sets of Fuel, AFR, and spark maps? Is this a hardware limitation?
Re: True Flex Fuel Support
For more Flex and blending options, upgrade to MS3.
The MS3 doesn't just blend between fuel, spark, and AFR tables, either - it also blends between separate cranking, AE, warmup, and other settings. The MS2 doesn't really have enough processing power to pull this off.
I'd love a more advanced flex fuel control for my MicroSquirt as well. Upgrading to MS3 on my motorcycle isn't really an option as I need the small form factor as well as the water resistance.
how about the ms3 pro range
