CAN gpio ADC rate?
(Runs on MS2 and Microsquirt)
CAN gpio ADC rate?
Postby ol boy » Sun Dec 03, 2017 10:29 pm
At what rate does the ms2 unit request the adc count from the expansion board?
306 SBFord, Torquer II EFI intake, 60 lbs injectors, 8 LS2 coils, VS Racing 7668 turbo, 4R70W, MS2extra 3.4.x_ish
ol boy
Re: CAN gpio ADC rate?
Postby jsmcortina » Mon Dec 04, 2017 5:17 pm
Every 10ms.
Postby ol boy » Mon Dec 04, 2017 7:06 pm
Im pulling baro data from an i2c sparkfun widget and then scaling to 10bit adc inside a teensy3.2. Is it possible to slow down the request rate to 1hz? Im planning to only sample the baro sensor once every 200 feet as i travel down the road. In ms2, what function would need adc over CAN at 100hz?
Thanks Ryan
ol boy
Postby jsmcortina » Tue Dec 05, 2017 5:23 am
The CAN polling is called from main(). You can alter the code to slow it down.
Postby ol boy » Fri Dec 08, 2017 9:42 pm
It took some bit of screwing around but i was able to get cygwin installed, loaded the tools and ran a "make release". I'll give it ago this weekend. How would one remove the lag factor for baro from using the same lag as clt,mat,battery? I cant seem to find where and how the lags are calculated.
Thanks Ryan
ol boy
