So orthogonal that I am not sure where to put this, but was struck last night by the fact that, having 4 VB921 drivers on boards, the GPIO might make an interesting ignition only controller. There is a real need for something between the MJLjr and a full blown MS setup and this might just be it.
Any thoughts?
GPIO as ignition controller.
I saw a post a while back that someone had taken the MS2/Extra code to use as a basis for GPIO, but he'd ripped out the ignition and fuel stuff.
Seeing as GPIO is the same CPU it would be pretty trivial to modify the MS2/Extra code to use the correct i/o. However we'd have to get the CAN code in place to grab the sensor data.
I suppose it depends what other inputs you need. If you only need a map sensor and the tach input then I suppose it is fairly simple. If you used an external MAP sensor then board fiddling is pretty much eliminated.Bill Shurvinton wrote:There are enough analogue inputs such that you could get it working without the CAN.
But then you are back to the question of why not get a PCB rolled that has just these features? Or the other question of wouldn't it be better to have a Megasquirt board that has all the required parts from day one?
To use the GPIO as a standalone ignition controller seems feasible but somewhat at a tangent from what it is "supposed" to be used for and could fragment the users even more if some are doing ignition on a spaghetti V3 and others on a GPIO.
