36-2 (rover MEMS)
36-2 (rover MEMS)
Having another think about one of the Rover trigger wheels, which 36-2 setup, but with the missing tooth every 180 degrees. If you used the cam sensor as well, with a pulse every 360 degrees and just told MS that the primary wheel had 34 teeth would this work, or would the tooth detector error handling get completely confused when it got a double gap it was not expecting?
If it just happily counts teeth in dual wheel mode then we have something that will work nicely.
Depends on whether you are trying to do dizzy or wasted spark.
If you use that 36-1-1 wheel on a 4cyl dizzy install then tell it you have an 18-1 wheel and set a single trigger point. That should "just work"
For wasted spark you might get lucky by using a cam trigger as well and choosing "2nd trigger" and "missing tooth" with 36-1
I'm running a Renix 44-2-2 wheel on my Volvo. It has a dizzy so no cam wheel or sensor.
If I set the tooth count to 22, the car would start and run up to about 2000 rpm whereupon I would get misfires, and they would get so bad the car would refuse to rev about 2300 ish.
I set the tooth count to 44, set trigger point A and Trigger return and left it at that and it works fine.
Hope that helps.
Hope that helps.
Hi there,
I have a look at the ms2extra_inc_wheel.c files. I don't know the .c files works, where they are mixed with the code.
But, is this patern correct for the 36-1-1 Rover wheel?
Is it right, usable? how?
Thanks!
Thierry
Code: Select all
/* ---------------------- Mini 36-1-1 ------------------------*/
} else if ((flash4.spk_mode & 0x1f) == 15) {
no_teeth = 34;
last_tooth = no_teeth;
no_triggers = 2;
deg_per_tooth[0] = 100;
deg_per_tooth[1] = 100;
deg_per_tooth[2] = 100;
deg_per_tooth[3] = 100;
deg_per_tooth[4] = 100;
deg_per_tooth[5] = 100;
deg_per_tooth[6] = 100;
deg_per_tooth[7] = 100;
deg_per_tooth[8] = 100;
deg_per_tooth[9] = 100;
deg_per_tooth[10] = 100;
deg_per_tooth[11] = 100;
deg_per_tooth[12] = 100;
deg_per_tooth[13] = 100;
deg_per_tooth[14] = 100;
deg_per_tooth[15] = 100;
deg_per_tooth[16] = 300;
deg_per_tooth[17] = 100;
deg_per_tooth[18] = 100;
deg_per_tooth[19] = 100;
deg_per_tooth[20] = 100;
deg_per_tooth[21] = 100;
deg_per_tooth[22] = 100;
deg_per_tooth[23] = 100;
deg_per_tooth[24] = 100;
deg_per_tooth[25] = 100;
deg_per_tooth[26] = 100;
deg_per_tooth[27] = 100;
deg_per_tooth[28] = 100;
deg_per_tooth[29] = 100;
deg_per_tooth[30] = 100;
deg_per_tooth[31] = 100;
deg_per_tooth[32] = 100;
deg_per_tooth[33] = 300;
trigger_teeth[0] = 0;
trigger_teeth[1] = 17;
trig_angs[0] = -300 + tmp_offset; // unknown
trig_angs[1] = -300 + tmp_offset; // unknown
Thanks!
Thierry
That won't work just like that because you need to add some sync code as well. (In ms2_extra_ign_in.c)
First, an Happy new year to everybody, hope your projects will work!
Hi James ( and all of you reading ;) ), I just didn't have the time to post , I have mod the renix parts (easiest for me):
ms2_extra_ign_in.c
So, will it work? How can I had it to the extra code for test?
Thanks again,
Thierry
Code: Select all
} else if ((flash4.spk_mode & 0x1f) == 16) {
no_teeth = 17; // for single coil
no_triggers = 1;
deg_per_tooth[16] = 200;
trig_angs[0] = -300 + tmp_offset; // to be determined
Code: Select all
SPKMODE16:
//initial sync
if (!(synch & SYNC_SYNCED)) {
if ((!tooth_diff_this) || (!tooth_diff_last) ) {
return; // only sync when there's enough data
// when unsynced we wait until we see a missing double tooth
if (tooth_diff_this > (tooth_diff_last<<1)) {
tooth_no = 0;
synch |= SYNC_SYNCED;
outpc.sync_status = 2;
} else {
return;
} else {
// recheck for sync
if (tooth_no == 17) { // (one less)
if (tooth_diff_this <= (tooth_diff_last<<1)) {
//fell over
ign_reset();
return;
} else {
tooth_no = 0;
if (synch & SYNC_FIRST) {
syncfirst();
goto common_wheel;
Thanks again,
Thierry
your flywheel ought to be 36-1-1-1-1 (36-4) it requires a differnt setup but i imagien it wont be long untill someone has that working!FridgeFreezer wrote:Watching with interest as I have a 1.8 K-series in the Freelander
220ft/lb@7900rpm@20psi ..13.3@114 .. 1.4 16v rover k-series engined rusty mini.
I'll try to look at this when I get chance.
I interpreted the above code and added it last night. Anyone who has a workable setup that they can test on please let me know and I'll send you some alpha code. I've a feeling the trigger angle is somewhat out, but that is easy to fix once an engine is synced and firing a coil.
