Alpha test: Suzuki swift
Post info and test results here
I don't have the MS2 chip, but will have one soon. Meanwhile, I have requested for alphatesters at the Teamswift forums. I am sure someone will try it before I get the chip.
http://www.teamswift.net/viewtopic.php?t=31646
Did that MS2 chip show up?
It gives me great pleasure [drums please ] to be the first to report that IT WORKS .
I tried beta 8, on a v3 board. Cranking advance (left) set to 6 degrees, spark output from D14. After minor VR pot adjustment, tach signal was correctly interpreted in MT.
The most noticeable difference is cranking/starting - the car cranks more aggressively and starts much quicker than with the grinded reluctor.
Went for a short ride - the car feels more responsive low/mid rpm.
So now it's finally true - all those swifters out there can use MS2 with their otherwise stock G13B engines, with no engine mods!
A big thank you to the MS2 extra developers!
[and sorry for the delay in testing, can't afford much downtime when you have only one car ]
And now onto closed-loop idle tuning . If you are interested in logs, just ask, no problem.
P.S. A note to everybody migrating from B&G code - be mindful of your maximum spark duration, or soon you'll discover an unexpected rev limiter .
Bye,
Tom
Bye,
Tom
Sorry, but I made it possible way before the MS2-Extra code. My custom 025mX and 029vX codes have been extensively used among the swift community.chense wrote:So now it's finally true - all those swifters out there can MS their otherwise stock G13B engines, with no engine mods!
Take a look: http://caaarlo.50megs.com
Anyway, it's good to know that now, the MS2 is swift compatible.
PS: I don't have any MS2 chip yet.
- lander
Please, can you send me your MSQ?chense wrote:I stand corrected.
I've been less than precise.
This is what it should said:Sorry .chense wrote: So now it's finally true - all those swifters out there can use MS2 with their otherwise stock G13B engines, with no engine mods!
Bye,
Tom
I am going back to use again Megasquirt.
Lander
Tell them exactly what you are trying to do.ronchinoy wrote:so when Im buying my kit.
Do I need to mention anything in particular or just buy a Mega 2 or 3 kit from anybody and it will work ?
