MS2/Extra 2.0 beta flashing issues
PLEASE vote in this poll - we need to understand whether this is a widespread issue.
To download MS2/Extra firmware you MUST use the download-MS2-firmware.bat file included in the zip. Do not attempt to use the original MS2 downloaders.
Test with the latest betas and if you have a problem also test with alpha20070610b. Then vote here.
Can load all firmwares fine, but only after I fiddle with my laptop. It has 2 COM ports, one in the base unit (Its a Compaq and has an extra MFU that has the floppy and DVD drive in it) and one on the laptop itself.
When you plug in the base unit, the one in the laptop itself shuts off. However, the one in the base unit gives me trouble under certain conditions. If the laptop is switched on and MegaTune isn't loaded, then MS won't boot. It also won't flash the new larger codes. It hangs halfway through. The one direct from the laptop doesn't have any of those issues, but I can't use it all the time because I need to run the base unit.
I hope that helps someone else, maybe either alter their settings or whatever.
Ya know, if the 64k problem is really limitted, why not just kind of do a "final 64k" version. Didn't MSII do something just like this for the early batch of CPU's that had less ram? That way if they don't want to just buy a new CPU, they can run the final 2.0 build, or they can buy a new CPU and continue on with the rest of us..
Brian
'84 Dodge Rampage
'84 Dodge Rampage
Given that the poll is 10:0 no problem at the moment, I don't think there is a real issue with the chip itself.
And you'll be coughing up ... HMMM lets say... 20% of the bill ill buy a new chip... As long as its Already Loaded with the latest beta....UnaClocker wrote:Ya know, if the 64k problem is really limitted, why not just kind of do a "final 64k" version. Didn't MSII do something just like this for the early batch of CPU's that had less ram? That way if they don't want to just buy a new CPU, they can run the final 2.0 build, or they can buy a new CPU and continue on with the rest of us..
I say that in total sarcasm... i mean seriously ...
still havent tryed "-d","-dw" yet ... as soon as i can ill try it..
MS-II Blue V3 PCB
MT 2.25 Final Release w/ MS2/Extra 2.0.1 Firmware
In a 1.9L 93 Saturn SC2 w/ GM DIS.....
http://www.cardomain.com/ride/741154
I'm sure he'll readily cough up 100% of the cost of the MS2/Extra code, ah that's because it is free.Lordprimate wrote:And you'll be coughing up ... HMMM lets say... 20% of the bill ill buy a new chip...
How come you didn't vote?
because i havent tryed the last thing you told me to try.... if it doesn't work then im going to vote
MS-II Blue V3 PCB
oK SO On my laptop..pettaw wrote:Can load all firmwares fine, but only after I fiddle with my laptop. It has 2 COM ports, one in the base unit (Its a Compaq and has an extra MFU that has the floppy and DVD drive in it) and one on the laptop itself.
I am using the one on the back of the laptop itself... I have been using that one for everything MS related... This laptop has 2 bays in the front... one is my battery.. and the other is my cd rom drive... (I can swap drives from a floppy to the cd).
I have tryed a couple of the other ports and they all Fail to do anything at the begenning and have an error code that says com # .... cannot be opened...
I have tryed beta 4 today ...
inserting "-d","-dw" doesnt change a thing..... as a matter of fact..
inserting "-d" doesnt do anything
Inserting "-dw" I get an error that says, "Input file cannot be read.."
Im missing out on all the great recent stuff... like the map sampeling changes(With my engine off my mapDOT fluctuates 10 units/-10/10/-10...), and the nitrous control(I cannot even trigger it with PA0 because its broken in 610b).... this just suxxors.. j
I have tryed com ports 2-4 and they all had the same "couldn't open com" Error...
i Inserted the d, dw into the BAt file .. in front of -v4 , behind -v4. No -v4 .. d... dw... dw500.. all to no avail...
i wish i had a different lap top... or new someone that would let me use their laptop... rule out my laptop as being the problem... I dont want to think it is ... but it just does't make sense that im the ONLY one with this problem still.... WTF
MS-II Blue V3 PCB
I just tried the latest beta and it would not load. I used the following command (because the batch file didn't work - have to look at that later):
ms2dl ms2_extra.s19
and I got:
MegaSquirt Download 1.05
Reading ms2_extra.s19:
ms2_extra.s19
Detected MS-II (HCS12) code.
Entry point: 0xc000
Code range: 0x4000-0x3dbe60
File read successfully
Opened comm port 1 at 115200.
Erasing main FLASH:
Erased.
Setting page register 0x3b:
Page set.
Erasing page 0x3b:
Erased.
ERROR: Timed out reading response, 0x0E
I have no problems loading the 1.0.2 release.
Let me know if you would like more testing.
Thanks!
Mike
ms2dl ms2_extra.s19
and I got:
ms2_extra.s19
Entry point: 0xc000
Erasing main FLASH:
Erased.
Page set.
Erasing page 0x3b:
Erased.
Thanks!
Mike
Nope.. pretty sure this is the first time I voted...muythaibxr wrote:Did you vote twice?
I only have two laptop machines ;)In any case, I'd like to see what happens when you try loading it using your desktop.
Ok.. tried that and it worked! Sweet! I like the jumperless install.The way you just tried it will not work with the boot jumper installed...
Using the ms2dl.exe that's included with the firmware, you should try:
ms2dl.exe -r 115200 -j ms2_extra.s19
However, your batch file doesn't work. CHOICE.COM will not run. Gives me the following error: "The system cannot execute the specified program."
There is definitely something funky about that COM file. The one included with 029v works fine. You might want to look into that. I'm running XPSP2 - nothing fancy - been working with MS1Extra for years.
Btw, for errorlevels, you want to list them in reverse order. This is a known issue for different versions of DOS, including the win variants:
http://www.robvanderwoude.com/errorlevel.html
Thanks,
Mike
The errorlevel order should still be reversed. This will ensure full compatibility with *all* versions of DOS/Win, not just the ones we happen to be using.Maglin wrote:Batch file works fine for majority. I think it's person settings and virus scanners or other apps that are conflicting. Wish we could change his vote.
Sorry about the negative vote - I'd change it if I could ;)
Mike
I voted because i cannot load it ...
I have tryed "Everyones suggestions"
I have use the BAT file Every time... and get the same Time Out Error... WHAT A BUMMER
The only thing i havent done yet is pull the MS inside and try my desktop... Mostly because is my daily driver right now... and i dont want to futz with it when im workn(dont want to be stuck at home reflashing just to go to work)
And i dont know anyone else with a laptop i can use for a day ...
ANYONE LIVE NEAR RICHMOND VIRGINIA?
MS-II Blue V3 PCB
Ok so after all that krap i am able to Upload the Latest Beta ... Beta 6
I havent tryed the IAC stepper UPdate ... as that wasnt posted when i was on...
I had use a Newer Dell Laptop and it flashed fine...
so ...
anywho ...
looks like i need to get this one reformatted ...
so
I now just need to get a good fuel table going .. and wait for the final release...
so ...
anywho ...
so
MS-II Blue V3 PCB
