MS2/Extra 2.0 beta flashing issues
Excellent. Glad you got it on their finally. Only other issue I can see is if you have it nested to far in and exceed the character limit of DOS. It's still their in XP. I found that out when I tried to flash with my laptop. Just moved the directory to root and it worked. BTW it said it couldn't execute the program in the cmd window.
Jeremiah
93 5.8 LX Mustang - MSIIextra
92 Eagle Talon TSI AWD Turbo - MSIIextra
when using my usb-serial dongle, i can firmware update MS2 and MS2/extra 1.0
But now when i am upgrading to MS2/extra Beta 13 it dident work.
After trying a lot of times with and without bootloader and different programs, and ports. with no luck
I tried another laptop with a real COMport and now it works.
I have posted the error messages if anyone can use them.
For me I found that to upgrade from B&G code require 2 steps. First upgrade to ms2 extra 1.0 using standard bootloader. Then upgrade to the newer versions with the download program. Couldn't get it to work any other way, and have done this on two different MS2's.
I went straight to the beta's/alpha's with both of my MS2 chips, no problem. Only problem I have been having is Win2k has made my built in serial port very flakey, I often get timeouts halfway through a flash. Sometimes they timeout in such a way that I have to put the bootjumper on and reflash the bootloader to get it working again! I've changed the port settings every which way with no luck. Even sending an MSQ to the unit in MT after a flash is hard to do, I get page timeouts on half the pages and have to send it 3 or 4 times before I'm pretty sure all of the pages made it.
I never had these problems with Win98 on the laptop.. I just upgraded to Win2k to get rid of some interface glitches in MT, as well as to gain hibernation support, which cuts my bootup times in half..
Oh, and MS1 never has a single problem in Win2k, but then, I'm not reflashing MS1 every week or two. ;)
Brian
'84 Dodge Rampage
'84 Dodge Rampage
Tried with the latest stuff, and I no longer have to do this.wes kiser wrote:For me I found that to upgrade from B&G code require 2 steps. First upgrade to ms2 extra 1.0 using standard bootloader. Then upgrade to the newer versions with the download program. Couldn't get it to work any other way, and have done this on two different MS2's.
Hello everyone,
It's a rainy cold day, so I figued I'd try to load up the latest Beta for my Neon since the Neon/420a crank reader seems to be pretty well sorted now.
Well, I've had a LOT of trouble getting this to load, and I'm wondering if there is any chance that my MS2 chip might be bad?
My old setup was MS1E ver 29t running fuel and spark Neon mode with two VB921s driving the coils, on a V3 board. I run a Dell laptop with XP for the operating system, and a real serial port (Com1).
Anyway, this is FRUSTRATING! ! !
I brought the MS inside to try to load it up using the stim (standard style) for power so I didn't have to unhook the coils until I got the setup configured for the inverted spark. I can't get the MegaTune to communicate with the MS no matter what I do, and I can't get the Beta loaded at all. . .
All I get when I try to do this is the same error message as mentioned above:
"ERROR: Timed out reading response, 0xE0"
Maybe I've got to try it in the car or something since I only have ~9V to the MS from the stim?
I've tried it on my laptop and now my desktop (also XP, and from a serial port I configured as described in the conversion instructions). Same crap either way. . .
I also used the regular bootloader program (is that what you call it?) to load up the last release I had downloaded, I think it was release 1.0.2. It seemed to load up fine, but then I couldn't get the MegaTune to communicate with the MS2. It says no response. . .
Then I tried again to reload the latest Beta from the batch file, and the same error message. . .
This is with the same laptop I use successfully for my MS1 tuning and logging.
Any ideas? I'd REALLY like to try out the MS2E!
Thanks in advance as always!
Thad
Thad
What options did you choose in the batch file?Tjabo wrote:Then I tried again to reload the latest Beta from the batch file, and the same error message. . .
I started by choosing the option for upgrading from MS2 code, because I thought that was probably installed on my chip as it came to me, and I went through that process, but as I recall, that didn't work all the way through.
Then I tried the "N" method, and that didn't work.
I tried both ways a few more times, with no luck before I used the regular bootloader method to install the release, and then went back to using "N".
Are there any other options I may have overlooked? These things are often USER ERROR when I'm involved!
Thanks,
Thad
EDIT: Oh yeah, I also unhooked my coils and tried this in my car. I used the "N" option. Same result. . .
Thanks,
Thad
Not enough information.Tjabo wrote:I take it that this doesn't indicate where it failed then?:
.. or something like that. . .
Okay, here's what usually happens:
Downloading new Firmware to Megasquirt board
PLEASE NOTE: This is for MS2 or Microsquirt ONLY !!
..............! ! W A R N I N G ! ! .............
This will wipe out ALL settings on the Megasquirt.
so if you havent saved the settings in MegaTune
it may be best to Quit and do it now !
MS2 or Microsquirt choice.
1 - MS2
2 - Microsquirt
Q - Quit
Select Megasquirt type [ MS2 ]: Q to Quit [1,2,Q]?
I choose "1"
Communication ports:
1 - COM1
2 - COM2
3 - COM3
4 - COM4
5 - COM5
6 - COM6
7 - COM7
8 - COM8
9 - COM9
Q - Quit
Select download port [ COM1 ]: Q to Quit [1,2,3,4,5,6,7,8,9,Q]?
I choose "1" again
If you are upgrading from standard Megasquirt2 code you will need to
use the boot jumper soon. If you are upgrading from a recent MS2/Extra
then this program will do it for you.
If you are unsure then press Y to quit - press Q
. Please read the README file!!!
Are you upgrading from standard Megasquirt2 code [Y,N,Q]?
I usually choose "N", especially since I seemed to successfully install the 1.0.2 release code.
1. Turn Megasquirt ON
Press any key to continue . . .
2. ! ! W A R N I N G ! !
!!!Ensure ALL Direct Driven Coils Are UNPLUGGED from MS ECU!!!
. If in doubt unplug all ignition coils from system!
. Damage to the MS ECU will result if you leave
. coils driven from the MS plugged in
ECHO is off.
ms2dl.exe -c1 ms2_extra.s19
MegaSquirt Download 1.05
Reading ms2_extra.s19:
ms2_extra.s19
Detected MS-II (HCS12) code.
Entry point: 0xc000
Code range : 0x4000-0x3dbcd0
File read successfully.
ms2_extra.s19
Entry point: 0xc000
Opened comm port 1 at 115200.
At this point it tends to "hang" for several seconds. . . Then eventually it says:
Anything else I can post up? I guess I'm about to reinstall my MS1Extra, since I have used up close to all of my available hours for this for today, and haven't even started to tune. There's always another day!
Thad
1 - MS2
2 - Microsquirt
Q - Quit
I choose "1"
1 - COM1
2 - COM2
3 - COM3
4 - COM4
5 - COM5
6 - COM6
7 - COM7
8 - COM8
9 - COM9
Q - Quit
I choose "1" again
ECHO is off.
ms2_extra.s19
Entry point: 0xc000
ms2_extra.s19
Entry point: 0xc000
Thad
Yeah, did 1.0.2 even have the new bootstrap?muythaibxr wrote:Try using the jumper as if you're installing from the standard firmware. Post those results.
You might want to change the batch file to say:
Code: Select all
Are you upgrading from MS2Extra v2.0 code and up (bootstrap already loaded) [Y,N,Q]?
Okay, with any luck, I'll get a chance to do that tonight after work.muythaibxr wrote:Try using the jumper as if you're installing from the standard firmware. Post those results.
Just to make sure I understand though, I should answer that I am upgrading from regular MSII firmware, and follow the instructions through to the letter, right? (and then post up all of the resulting info like I did above)
Thanks again for all of the effort guys!
Thad
Yes, because 1.0.2 did not have the bootstrap, which means you're starting from the same place as if you're coming from the standard MSII firmware...Tjabo wrote:Okay, with any luck, I'll get a chance to do that tonight after work.muythaibxr wrote:Try using the jumper as if you're installing from the standard firmware. Post those results.
