quick update on next beta
Alright, due to the business of this weekend, and of last week, I'm way behind in posting the next beta.
I *believe* I have fixed the distributor timing issues, the timing was holding steady on an engine, and on the scope at Spectre's headquarters.
I've also got that fix in for PID lockout on idle speed control.
I'm going to do a quick release without fixing any other bugs in the next day or two, then I'm going to focus on fixing all the known bugs.
I'd also like to get a few more features from ms1/extra ported over while I'm at it, but not until the bugs are all fixed.
I also plan on adding an extra feature to the MAP sampling code to make it so you can sample closer to the "next" tach event instead of sampling right after the "previous" one.
d*** that sucks - good luck with it!muythaibxr wrote:alright, turns out part of the dizzy problem is still there, along with another dizzy problem that's even worse.
It might take a little longer to fix then I thought, so I'm going to hold off on the next beta until I'm pretty sure it's fixed.
I want to test MS2/E on my car but I am hesitant as I definitely need over boost protection!
Keep us updated as usual
1992 BMW 525i M50 Non Vanos 24v Turbocharged
Stock COP Wasted Spark
MS2/E v3
MS2/E v3
Ken,
Don't know if this will help.
Setup = basic trig.
Trigg angle = 13
input capt. = falling edge
spark out = Going High
no prediction
std. dwell
Car is 5.0L Ford w/TFI. The Engine fall on its face at about 3100 to 3200 and i can't get past it feels like the rev limiter is on... notice the rpm peaks. I took out the spark out jumper going to the TFI module and now can rev as far I want too. Of course I also have no advance either...
Ed
Setup = basic trig.
Trigg angle = 13
no prediction
std. dwell
Ed
Well, I was using dizzy mode to see the spark output signal as I do
not have a Jim Stim. It sure looks like and feels in my car like what
Ed sees with Dizzy mode, but I am running it in 36-1w/second trigger.
From the testing I was running in Dizzy mode the other night, the
spark line goes to 0V when it hits a certain RPM and that RPM seems to
be linked to the length time after spark that I want it to hold the
spark line down. If this has nothing to do with generic wheel mode, I
dunno what to say. Just trying to help.
KeithG
KeithG
It looks like when dwell crosses the edge of the input signal
that's not
supposed to be getting used, it gets lost until it finishes crossing that
point. That's what I saw on the scope last night.
That leads me to think that the input capture settings are not correct for
normal dizzy mode.Ken
Alright, due to the fact that I probably won't have time to do any in-depth coding until the weekend (busy time at work this week), I'm going to do a release tonight with the MAP fix for EDIS, and the closed-loop PWM idle fixes.
The next beta after that will contain at least the distributor fixes, as well as any other fixes I have time to do.
