Output problems
Output problems
I can't get outputs to work at all in Beta 5. They do not work in Beta 4 either. Basically, the settings have no effect- in my case, my injection LED just stays off until start, then comes on and stays on. It is disabled, but I had it set as a coolant temp controlled output.
Insaner yet, burning the firmware does not fix it. It just does even weirder things.
95 Miata M-Edition, GT28 Turbo
on msefi there is a HUGE obnoxious red message above the text box every time one posts, perhaps you could put a smaller milder more concise one on this site. if you just say such a thing in this thread, it wont see as a large audience that it might need to.
with regards the msq comment of course... just a thought.
fred.
fred.
ms2,v3,cop,innovate,mazda fe3/fe-dohc 2l 4cyl with stock 10:1 pistons,4 stock coils,4 stock ignitors,rx7 550cc injectors maxed@6600rpm&17psi,custom everything,holset he351cw turbo,44mm ext gate,nis gtr bovs,nis gtr intercooler,70mm lexus throttle,chinese fpr,10may v2 ms2e alpha code
pleeeeeeaaaaaaase make it a short one. the benefit is that people may bother to read it. i know i have never stopped to read the entire 3 lines of lances message.
fred.
fred.
Yep, I'm sure nobody has ever mixed those LED's up......uh well, Don't feel so bad, I've done that before too.natesully wrote:ARRGH I'm stupid! The middle LED is warmup, not injection!
I sat here for 30 minutes wondering why it always comes on below 160 degrees
After moving my port settings from "Injection" to "Warmup LED", everything is good.
Cheers!! for figuring it out so fast!!
Scott
That was pretty quick Ken.muythaibxr wrote:Probably not a bad suggestion, I'll have to see how they did that.
I also didn't mean for that comment to be rude or anything, nor did I mean to direct it at any one person.
Jeremiah
93 5.8 LX Mustang - MSIIextra
92 Eagle Talon TSI AWD Turbo - MSIIextra
