EAE + long MAP hoses
Is anyone running long MAP lines (a few meters or more)? Will placing MS behind the passenger seat kill my EAE with evil lag?
95 Miata M-Edition, GT28 Turbo
You could measure that yourself actually...
I'd think it might slow things down a bit, but I'm not sure it'll give you "evil lag."
The easiest way to find out is to put a really long MAP line on there without moving the MS to the new location. Whether it runs different or not, you'll have your answer, and for the cost of a few feet of MAP line (probably not expensive.)
I would- but my car will not run, I have MS wired to the new location (factor computer harness) already. My guess is it won't be that bad, since the vacuum pulses travel at the speed of sound, and I don't think my valves or throttle have broken the sound barrier lately.
somewhere around (the manual probably) it says bruce n al did an experiment with 30ft of hose, and couldnt measure the delay... should be sweet provided its not huge/tiny hose.
ms2,v3,cop,innovate,mazda fe3/fe-dohc 2l 4cyl with stock 10:1 pistons,4 stock coils,4 stock ignitors,rx7 550cc injectors maxed@6600rpm&17psi,custom everything,holset he351cw turbo,44mm ext gate,nis gtr bovs,nis gtr intercooler,70mm lexus throttle,chinese fpr,10may v2 ms2e alpha code
yes, and many do, but i'd be paranoid about noise before i was about the throttle plate doing mach 4
When I first installed mine, I had a gm 3-bar mounted under hood with 1' of hose. I then changed to a board mount 3-bar with 8' of hose. Couldn't tell a difference in anything.
