Modifying code
you could always code it the dirty way in the mean time before this is resolved by duplicating the code...
just a thought.
just a thought.
ms2,v3,cop,innovate,mazda fe3/fe-dohc 2l 4cyl with stock 10:1 pistons,4 stock coils,4 stock ignitors,rx7 550cc injectors maxed@6600rpm&17psi,custom everything,holset he351cw turbo,44mm ext gate,nis gtr bovs,nis gtr intercooler,70mm lexus throttle,chinese fpr,10may v2 ms2e alpha code
Have you examined the assembly output to see what it is doing?
Modifying code
Not to waste your time, but I did not know we could do that... How do we see that code? I just tried to look at the *.o files and they are binary. Is there a way of seeing the ASM. I am compiling the code using the 'make.bat ' file with the installed ms2compiler.zip package. The only files created in the directory I am using are the *.o files and the *.s19 when I double click on make.bat.
KeithG
On 8/24/07, jsmcortina wrote:
KeithG
I checked the assembly output generated on my PC and it is doing what you asked it to do.
do a -S in there somewhere and it wont go past making the assembly code.
fred.
edit : those last 2 posts appeared in reverse order in my email...
fred.
Ah yes... without using cygwin the "objdump" command doesn't work (for some reason) so the assembler output isn't created.
See the difference between Makefile and Makefile.DOS
Here's a snippet from the ms2_extra.dmp with the original code:
Code: Select all
000fc410 <LSM82>:
} else {
if (outpc.tps > (int)flash5.pwmidle_tps_thresh) {
fc410: fc 39 c5 ldd 39c5 <outpc>
fc413: bc 44 29 cpd 4429 <flash5>
fc416: 2f 2c ble fc444 <LSM93>
000fc418 <LSM83>:
if (outpc.rpm > rpm_thresh) {
fc418: bd 39 b3 cpy 39b3 <outpc>
fc41b: 24 0d bcc fc42a <LSM87>
000fc41d <LSM84>:
DISABLE_INTERRUPTS;
fc41d: 14 10 sei
000fc41f <LSM85>:
IACmotor_pos = flash5.pwmidle_closed_duty;
fc41f: f6 44 24 ldab 4424 <flash5>
fc422: 79 39 a4 clr 39a4 <IACmotor_pos>
fc425: 7b 39 a5 stab 39a5 <IACmotor_pos>
000fc428 <LSM86>:
ENABLE_INTERRUPTS;
fc428: 10 ef cli
000fc42a <LSM87>:
if (IACmotor_reset == 0) {
For debugging without BDM, use outpc.statusXXX in the code and display them in Megatune.
e.g. set outpc.status3 to zero normally and then set it to 1 if that section of code executes. That allows you to confirm what part of your code is malfunctioning. I think that you are unexpectedly executing some of the rest of the code due to that "OR" operation.
If I recall correctly, the "simplified gcc" package has a different release of the compiler (or different options) to the one Ken is using to build the code. I wouldn't be unduly worried about it.
Ken/James,
I have been having troubles compiling the s19. Most every time I make an edit, it will load, but will generally lock up MT as I am cranking. I have noticed that when I use make.bat that the file size is off from the 'shipping' version by about 10k. I asked Shawn to compile it from Cygwin and he gets the same file size as the shipping version. I do not know if it is the compiler that is the problem, or the options set in the makefile.DOS, or what, but there seems to be a discrepancy. Is this something to worry about?
KeithG
KeithG
Keith,
Depending on the nature of your edits, all kinds of undesirable things might be happening with the firmware.
Also, as James mentioned earlier, the difference in size of resulting binaries is of minor importance.
For others planning to modify the code while using cygwin, here is the link where i got my ported gcc compiler for the hcs12 cpu: (download the one for windows and put the stuff that's in /usr inside the zip, into the cygwin's /usr)
http://www.gnu.org/software/m68hc11/m68 ... nload.html
It had compiled the original code just fine (no errors) but i have not yet tested it running on the hardware.
Will update with progress.
btw, i plan to play around with the wheel decoder code
is it still possible to compile in codewarrior ? which version/addons do i need ?
I like my proper development UI with code highlighting, bracket tracking, line numbers, and definitely advanced debuggers and stuff. I just want to play around and 'get my feet wet' with ms2 programming....
BMW, 1985, E30, 325i, 2-door, 5spd. Lots of custom work. Turbo build in progress: http://www.e30tech.com/forum/showthread.php?t=55733
not as it stands because of the way inline asm is handled and possibly other things too.
EDIT: Here's a good read on dev tools, of a different kind:
http://tools.diyefi.org
http://forum.diyefi.org/viewtopic.php?f=41&t=547
http://forum.diyefi.org/viewtopic.php?f=41&t=1103
http://forum.diyefi.org/viewtopic.php?f=41&t=1683
http://forum.diyefi.org/viewtopic.php?f=41&t=1689
http://forum.diyefi.org/viewtopic.php?f=54&t=1381
try eclipse or similar, it supports gcc development.I like my proper development UI with code highlighting, bracket tracking, line numbers, and definitely advanced debuggers and stuff.
We found and fixed a bug in the DOS Makefile that was breaking code compiled under DOS. The Makefile.DOS in the latest 20071104 beta should be working correctly.
