Modifying code
Modifying code
I tried the make.bat file in the src directory. How do we recompile MS2/E?
KeithG
KeithG
You have to get the gcc package that was put together, or you have to go get cygwin and download the compiler package, and then build it inside cygwin.
The gcc package is here:
http://prdownloads.sourceforge.net/mega ... p?download
Your question doesn't make sense. You HAVE to use gcc, either the latest package from the gcc for hcs12 site, or the one that I linked in my last post on this thread.
EDIT:
Planning on adding a new feature?
EDIT2: Maybe my previous post wasn't clear... You either have to get the package that I posted a link to above, or get cygwin, and download the latest gcc package from the hcs12 site. Either way you're using gcc.
With cygwin, you get close to a real UNIX-like environment, so you can use things like make, and patch.
EDIT:
Modifying code
Oh. Sorry, I was not clear...
I had heard (read) a while back that someone was having trouble with
GCC making bloated or possibly incorrect code. I'd rather use GCC
unless there is a distinct advantage in the code created using Cygwin.
KeithG
KeithG
cygwin is a win package so that it acts like linux. you have to use gcc whether its wrapped in cygwin or raw in windows, or raw in linux...
no other way without back porting the code to codewarrior and fixing all the stuff that will break and paying for an expensive version to handle the size.
hope that helps.
fred.
hope that helps.
fred.
ms2,v3,cop,innovate,mazda fe3/fe-dohc 2l 4cyl with stock 10:1 pistons,4 stock coils,4 stock ignitors,rx7 550cc injectors maxed@6600rpm&17psi,custom everything,holset he351cw turbo,44mm ext gate,nis gtr bovs,nis gtr intercooler,70mm lexus throttle,chinese fpr,10may v2 ms2e alpha code
Re: Modifying code
Keithg wrote:Oh. Sorry, I was not clear...
Cygwin doesn't generate the code... you download the compiler and use it from cygwin, or you download from the link above, and use that. Either way you're using gcc, it's just a matter of the environment you compile from. The generated code is the same either way.
You planning a new feature?
Modifying code
Ok, now it is a bit more clear. Sorry I was not as well informed as I probably should have been. I was used to MS1/E and just clicked compile... This is just a bit more complicated for us MEs.
No new features, just trying to learn C so that I can play around a bit.
KeithG
KeithG
Keithg wrote: Oh. Sorry, I was not clear...
I should be pretty familiar to anyone who's done any work in Linux/FreeBSD/*nix. If you haven't done that then it's understandable that it's not that familiar.
In either case, once you have the tools you need, it's not difficult... it's as simple as double clicking make.bat, or typing "make" on the commandline.
As Ken says, we only use gcc. While it does generate some bloated code, we've done our best to work around that.
You'll also need to learn HCS12 assembly. Not that different from HC08 assembly though.
Ok, I have tried one modification with the 0812 package. I grabbed the GCC package as instructed. I Modified the code. It compiled (no errors) and I was able to U/L the new S19 to the MS. I calibrated sensors, I loaded the latest MSQ and all looks good. When I try to crank it, the MT screen goes red (disconnect) and it locks on the fuel pump. I have to power down and wait a minute then I can reload the original S19 file and all is well again. Is this an indication that I made some syntax or other programming error, or am I doing something else odd.
All I edited was the *misc.c file. and I double clicked on make.bat then uploaded the s19 file that was created in the directory.
KeithG
KeithG
You've missed an opening brace out of
} else if (IdleCtl == 6)
The other thing worth trying is to compile the stock code and make sure it works the same as the bundled s19. That way you know that your compiler and build environment is working correctly.
Another tip - update sigs.c as you work. This way you'll get confirmation via the date/time in the Megatune title that you have uploaded the correct code.
Don't you do this automatically? Just use the predefined symbols __DATE__ and __TIME__ to embed the compile time into the code:jsmcortina wrote:Another tip - update sigs.c as you work. This way you'll get confirmation via the date/time in the Megatune title that you have uploaded the correct code.
char *sig = "MSe-II " __DATE__ " " __TIME__;
Well, I am able to compile the MS2/E code as delivered. It uploads and works as far as I can tell exactly as the released S19. The only thing I noticed is that the S19 I generated is smaller than the one in the released package. Mine is 172kb and the released version is 183 kb.
I went through it and cannot see where I am missing a brace. I am using notepad++ and it highlights the braces and parentheses. Is there an editor for the HC12 which is more 'helpful' with this?
KeithG
KeithG
jsmcortina wrote:You've missed an opening brace out of
These predefined macros are part of the C-preprocessor and have been around for decades. They are now part of the ISO standard for the language, along with a handful of others.muythaibxr wrote:IF that's something cvs does, then keith can't do it as he doesn't have CVS access.
http://www.linuxtopia.org/online_books/ ... NED-MACROS
Ok, As I previously said, I am not a programmer, so this is a bit hard for me. I have been able to compile and load code, but this test does not seem to work. The bit I am trying to modify is:
I want to change the first part to
The code compiles, but it never will allow the OR test. It does not matter if the order is reversed (rpm first then tps). It only acts on the TPS test. What am I missing?
KeithG
Code: Select all
if (outpc.tps > (int)flash5.pwmidle_tps_thresh) {
if (outpc.rpm > rpm_thresh) {
DISABLE_INTERRUPTS;
IACmotor_pos = flash5.pwmidle_closed_duty;
ENABLE_INTERRUPTS;
if (IACmotor_reset == 0) {
IACmotor_reset = 1;
DISABLE_INTERRUPTS;
idle_wait_timer = 0;
ENABLE_INTERRUPTS;
last_rpm = outpc.rpm;
Code: Select all
if ((outpc.tps > (int)flash5.pwmidle_tps_thresh) ||
(outpc.rpm > rpm_thresh)){
DISABLE_INTERRUPTS; ...
KeithG
Keithg wrote:Ok, As I previously said, I am not a programmer, so this is a bit hard for me. I have been able to compile and load code, but this test does not seem to work. The bit I am trying to modify is:I want to change the first part toCode: Select all
if (outpc.tps > (int)flash5.pwmidle_tps_thresh) { if (outpc.rpm > rpm_thresh) { DISABLE_INTERRUPTS; IACmotor_pos = flash5.pwmidle_closed_duty; ENABLE_INTERRUPTS; } if (IACmotor_reset == 0) { IACmotor_reset = 1; } DISABLE_INTERRUPTS; idle_wait_timer = 0; ENABLE_INTERRUPTS; last_rpm = outpc.rpm; }
The code compiles, but it never will allow the OR test. It does not matter if the order is reversed (rpm first then tps). It only acts on the TPS test. What am I missing?Code: Select all
if ((outpc.tps > (int)flash5.pwmidle_tps_thresh) || (outpc.rpm > rpm_thresh){ { DISABLE_INTERRUPTS; ...
KeithG
You are missing a ")" at the end of the expression.
DISABLE_INTERRUPTS; ...[/code]
ahta should get it to compile.
Raul
soon to be squirt&sparked 89 mkIII Supra, Using:
MS2 processor (pins 10 & 15 modded), v3.0pcb,
stepper IAC, P&H boards, *ERROR -extra board,
in 6cyl wasted spark configuration.
Jun-10-2007 alpha code.
Raul,
Thanks, but that was a typo on my part. I have that parentheses closed and edited my code listed above. I can get it to compile, and all looks good, but it ignores the test for the RPMs above the threshold.
Could it be that this is set up like:
If (test) {stuff with if statements}
Else {stuff with if statements}
that it seems to ignore the OR statement in the first IF?
KeithG
KeithG
