I think it would go Lean for Just a second...Jon k wrote:I am going to be running a wet kit and its my first nitrous endeavor. Only 50hp to spool we we discussed - will I need to add fuel if using a wet kit? I am just an over-thinker and conerned what a friend has told me that when nitrous comes on, it can be lean for a split second. If that's true it'd be nice to dab some fuel in there but I cannot see how this is an issue. Argh - I guess I have to figure it out!
the Nitrous is under a higher pressure....
and alot of people have a purge kit that aids in the Quickness in the delevery...
the fuel however, is at a lower pressure... and its a fluid ... so it will take a split second for it to fill the Solenoid Feed line, And then From the Solenoid to the Jets....
Thats why people use the Fuel Pressure Saftey Switch...
If you get one with a high pressure switch. it will keep the nitrous from activating until there is Pressure in the Fuel Feed line....
at least thats why i thought people used the fuel pressure switch
