Closed loop idle bug?
Closed loop idle "stalled" today without any reason? PWM stalled to 90% (fully open) even rpm was over target? Using MS2 Extra beta8
Opel Kadett C City 2.0 16V Turbo
That is weird. First things I would ask are:
is 90% truly a good value for 'open'. It is a good idea to have this value be slightly above a normal idle value on a hot day with all accessories running.
is 37% actually the closed duty? This is the value when the valve is closed all the way. I would suspect this should be either 0 or 25% for the 2 types I have seen and used. There may be others that I am unaware of, but AFAIK...
It appears that your idle can regulate at target RPM (end of the log) at ~40. You may want to play with RPM lag to make sure it always gets a good rpmdot value. The code defaults to 50. I ended up having to use 30 to get it to reliably get out of lockout. Also, your map at idle is pretty high. Is there some reason it is at 50? (cam, A/C running, etc) If this is a normal idle MAP value, you can bring your PID lockut map value closer to your idle MAP value. If it normally idles at 50 map, you may want to try 48 as a PID lockout value.
Maybe Ken will see something I did not, but closed loop idle is pretty exacting in the values you need to have for it to work well.
HTH,
KeithG
HTH,
KeithG
Opel Kadett C City 1.2i Tbo MS-II PCB V3 squirt'n'spark
Is 37% really your closed value? that seems kind of high. On my setup i used 15% and that was really where the valve stopped moving at the low end. (use "Warm up only" to get this) I had to lower my idle screw at the lower end to get it to idle lower than 1000rpm because the stock Ford computer expects 1volt tps at idle.
I would tweak your PID a little better. I would try bumping up your proportional gain and lower your Intregal gain a little if it's hunting.
Also I see your Idle Spark advance is pretty low, you should run this up more to get more torque at idle to make it less likely to stall. You have around 9 degrees of advance at idle, I would run closer to 20-30degrees advance at idle and you'll see better idle quality.
Oh, also your VE table lower values drop off at idle a bit at lower Map, richen it up around the edges a bit and that will help.
It is actually 37%. Valve still moves if I go lower , BUT then it will open from other end. That is kind of fail safe position in wire break situationMegaScott wrote:Is 37% really your closed value? that seems kind of high. On my setup i used 15% and that was really where the valve stopped moving at the low end. (use "Warm up only" to get this) I had to lower my idle screw at the lower end to get it to idle lower than 1000rpm because the stock Ford computer expects 1volt tps at idle.
I was just starting to do PID tuning (with NZ-method), so those aren't final values.I would tweak your PID a little better. I would try bumping up your proportional gain and lower your Intregal gain a little if it's hunting.
Stock engine has 4-6 degrees idle advance. My engine is old Opel OHV engine (1.2 litres) from 70's.Also I see your Idle Spark advance is pretty low, you should run this up more to get more torque at idle to make it less likely to stall. You have around 9 degrees of advance at idle, I would run closer to 20-30degrees advance at idle and you'll see better idle quality.
All the newer OEM's use a scheme where the idle advance is upwards of 30degrees advanced, this serves two purposes, one it increases torque, so accessories such as A/C and alternator do not drag the engine down so much, plus it gives you more control when letting out the clutch.teg wrote:Ok, thanks for your hints and comments. Hope emissions won't (HC) won't go too high..
BUT I still have problem with Idle valve control...
I suspect as soon as you raise your idle advance you'll see the engine idle go up to a point where you will need ot lower your throttle blade opening, this will cause the Idle control valve to be forced open more, giving you more control over your idle.
Your Proportional gain is a little low, this could cause sluggish operation in closed loop, bump it up to 20 or higher.
Also your Integral might then be a little high, this can cause excess hunting, lower that until the hunting goes away, it will still over shoot a bit, but now that you have more air and more control over your idle it should only overshoot once a small amount, then settle down to the target speed.
Actually, your HC may actually improve based on what Scott says. Basically, increase timing at idle until idle quality decreases. You will note this as MAP will continue to decrease then level out. Since you are mapping timing, you will not affect any of the rest of the map, only around idle. In carb days they used to have a slightly rich idle as a slightly rich idle is more stable than slightly lean. With EFI, you can get closer to a stoich idle which helps the 3 way catalyst (if so equipped) and idle quality.
KeithG
KeithG
Hmm..
Interpolation of target rpm has done by this way:
And prototype of intrp_1ditable is:
What if pwmidle_clt_temps has negative values (as I have)?
Code: Select all
targ_rpm = intrp_1ditable(outpc.clt,8,(int *)pg5_ptr->pwmidle_clt_temps,
(unsigned int *)pg5_ptr->pwmidle_target_rpms);
Code: Select all
unsigned int intrp_1ditable(unsigned int x, unsigned char n, unsigned int * x_table, unsigned int * z_table)
You say that newer engine managements run at around 30btdc idle advance ?, hmm, thought i was seeing ghosts when i was getting into that area myself......, thought that something must be wrong for this to work so good. Car was really nice to drive in "jammed" traffic, no need to touch the throttle at all, just clutchworkMegaScott wrote:
But hey, i´m not using MS2 extra, YET(getting there soon), so i´ll shut up now.
Peugeot 309GR1990 XU9JAZ(4cyl 1.9litre) 10.8:1 CR with 60-2 VR wheel decoding ,V2.2 card, singel coil and dizzy spark ,360cc 0 280 150 431 injectors. Msns-E hi-res 10d2 and E85(Ethanol) in the gastank.
Could be the problem. I'll check into it.teg wrote:Hmm..
And prototype of intrp_1ditable is:Code: Select all
targ_rpm = intrp_1ditable(outpc.clt,8,(int *)pg5_ptr->pwmidle_clt_temps, (unsigned int *)pg5_ptr->pwmidle_target_rpms);
What if pwmidle_clt_temps has negative values (as I have)?Code: Select all
I knew we should have used Kelvin..teg wrote:What if pwmidle_clt_temps has negative values (as I have)?
woooooooo hoooooooooojsmcortina wrote:I knew we should have used Kelvin..teg wrote:What if pwmidle_clt_temps has negative values (as I have)?
please metricise the code
that would be cool indeed. properly pure scientific grade code
i actually exclaimed "yes!!" when i read that. shows just how sad i am ;-)
fred.
ms2,v3,cop,innovate,mazda fe3/fe-dohc 2l 4cyl with stock 10:1 pistons,4 stock coils,4 stock ignitors,rx7 550cc injectors maxed@6600rpm&17psi,custom everything,holset he351cw turbo,44mm ext gate,nis gtr bovs,nis gtr intercooler,70mm lexus throttle,chinese fpr,10may v2 ms2e alpha code
