Code mod: inverting fastidle output
(Runs on MS2 and Microsquirt)
msoultan
Post by msoultan »
I'm looking to make a slight modification such that fastidle turns on when it reaches the cutoff point, instead of turning it off.
Code: Select all
if(IdleCtl == 1)  {
	if(outpc.clt < flash4.FastIdle)
	    *pPTMpin[2] |= 0x04;             // turn on fast idle solenoid
	if(outpc.clt < flash4.FastIdle - flash4.IdleHyst)
	else if(outpc.clt > flash4.FastIdle)
	    *pPTMpin[2] &= ~0x04;            // turn off fast idle solenoid
Looking at the above code, it would seem like all I need to do is switch around the '<' and '>' signs.
The only thing I didn't know is if I need to swap the '<' for the hysteresis.
Honestly, I don't know what that hysteresis code actually does. Assuming the fidle value is 160 and the hysteresis value is 5 a temperature of 159 will turn it on and a temperature of 160 will turn it off. If it hovers up and down around there, it's still going to turn on and off.. I don't get it.. or I'm looking at it wrong?
Thanks!
Mike
racingmini_mtl
Re: Code mod: inverting fastidle output
Post by racingmini_mtl »
No wonder you don't get it: the code is wrong. The hysteresis is not really implemented with the code above. The first 'if' that turns on the fast idle solenoid should be removed:
Code: Select all
if(IdleCtl == 1)  {
       *pPTMpin[2] |= 0x04;             // turn on fast idle solenoid<br>
So now if you want to invert the behaviour, you can just switch the '<' and '>' signs around as you proposed.
Cheers,
msoultan
Post by msoultan »
haha.. that had me so confused! Thanks for the help! I posted a message on the MSEFI forums as well letting them know about the error.
Thanks!
Mike
cmcook
Post by cmcook »
Can't you just turn FIDLE off and then set it in Output Ports? I am using the FIDLE output to switch my fan relay on when above a set temperature. No need to fiddle with code.....
msoultan
Post by msoultan »
cmcook wrote:Can't you just turn FIDLE off and then set it in Output Ports? I am using the FIDLE output to switch my fan relay on when above a set temperature. No need to fiddle with code.....
thank you so much for that suggestion! I've never played with the Output Ports before. Makes life much easier!
Thanks!
Mike
