JS11 internally pulled low? Launch switch input
Trying to get the launch switch to work with beta8 on v3 board, but nothing makes sense - built the circuit with two protective diodes (one from JS11 to +5V on the proto, one from JS11 to the switch, switch tied to ground). Diodes checked OK.
The problem is that nothing pulls JS11 high - with the diode to +5V, the voltage there is .17V (between JS11 and the ground). With a pull-up of 2k2 the voltage is 0.22V, wtf?
[the JS11 was selected in MT as the launch input during measuring, TPS was over the launch threshold]
Same situation when tried with JS7 and JS10 (tried with just the diode, not the pull-up) - nothing pulls the port up.
What am I missing?
Thanks,
Tom
What am I missing?
Thanks,
Tom
No problem, here is it.muythaibxr wrote:You might not be missing anything, there could be a bug.
In any case, can you post your msq?
What about this piece of code (ms2_extra_init.c, function main_init(void), line 374) :
Code: Select all
if (pPTApin0 == &dummyReg) {
conf_err = 7;
} else {
pPTApin0 = &dummyReg;
//need to configure as input and setup pullup
Bye,
Tom
For me too launch do not work on js11. As I understand I have no hope to get it working until Saturday?
Some of my instalations:
VW TBI, VW 16V 60-2,
BMW M50 COPs 60-2, BMW M20 and M50 ITBs as Alpha-N, BMW M20 turbo Wasted spark
Opel 20XE Wasted Alpha-N with ITBs
Audi 10VT Audi20V
MR2 3S-GE.............
and over 100 tuned
Audi 10VT Audi20V
and over 100 tuned
Did you try any of the other input in the drop down box in megatune while hooked to js11?
I ended up changing my setup to this
http://www.msextra.com/viewtopic.php?p= ... ht=#165235
And it has worked with both 7 and 8
Just try. JS11, JS8, JS7 do not work for me. It is on 20010812 version.
Is some indicator for launch control in Megatune? I see three empty cells between other indicators.
Gints.
Gints.
Audi 10VT Audi20V
and over 100 tuned
Audi 10VT Audi20V
and over 100 tuned
launch is working in beta10, i had ran into the same problems as all of you didnt know why. Happy to know that it is now working, just tried it out.
260Z Turbo MS2 Extra Beta9, Error* board, MSD 6AL
WWW.DFWDatsuns.com
WWW.DFWDatsuns.com
