Hello. Im a bit lost .
Im trying to install the Megatune for the MS2 Extra with one of the latest beta codes, but i dont achieve to gain acces to the extra code/features.
How do you install/setup the beta codes?
How to install latest realeases
Seems like it'd make more sense to have had the second option be "Spark Only". What's the difference between "Fuel+Spark" and the next two options? That's kind of confusing.MegaScott wrote:MS2Extra has a feature to simplify the menus, allowing you to choose between four different user levels.
"Basic Setup" menu->"Basic/Advanced user" dialog.
Choose dropdown menu-
"Fuel only"
"Fuel+Spark"
"Extended"
"Advanced"
Choosing these different options will enable or disable certain menus.
Brian
'84 Dodge Rampage
'84 Dodge Rampage
Spark only is just without injectors hooked up.UnaClocker wrote:Seems like it'd make more sense to have had the second option be "Spark Only". What's the difference between "Fuel+Spark" and the next two options? That's kind of confusing.MegaScott wrote:MS2Extra has a feature to simplify the menus, allowing you to choose between four different user levels.
"Fuel only"
"Fuel+Spark"
"Extended"
"Advanced"
It's not at all that complicated, just choose the approprate one. If you want to choose from a menu item, and it's greyed out you need to move up to "Advanced" which enables all the bells and whistles, of course that also allows you to mess with some of the more advanced settings which could cause problems if you don't know what you are doing.
