want to migrate from ms1xtra to ms2xtra
hi guys i quick ? i want to migrate to ms2xtra but my board (v2.2 )is modified to use the gm 7 pin as a vr conditiner acording to the ms1xtra documentation do i have to change something to make the ms2 chip to work or should i leave it like that and i aint going to have any problem i dont want to burn the chip. thanks
Electrically the MS1 and MS2 chips are both 0-5v for all inputs and outputs.
There are different pins used for some of the inputs and outputs, which you may need to check, but the signals themselves are the same.
For 4cyl and 6cyl wasted spark the tach input and spark outputs are the unchanged.
Check the input/output wiring guide.
http://www.msextra.com/ms2extra/MS2-Ext ... .htm#iouse
