It is very easy to have a low boost setting (full boost reference to wastegate) and a MS controlled boost setting (which obviously has to be higher than the base wastegate spring setting).
This only takes a simple switch totally outside of MS.
boost control
Is there a way to have the MS boost setting as well as a configurable low boost setting? I bought a really low spring so running on spring/PWM isn't really an option for me..
'93 BMW 325iS - Rebuilt M50 w/ 0.140" HG (~8.9:1 w/ head/block decking), Custom turbo system T3/T4 .63 .50, Megasquirt v3.57 MSnS-II/Extra
