MS2/Extra beta 10 (20070930)
(Runs on MS2 and Microsquirt)
muythaibxr
Post by muythaibxr »
Fixes/Changes in this release include:
1) Removed page 10 (no functional difference, but possibly more space for new wheels)
2) Fix for wheels with less than 12 teeth. Dwell on spark A may occasionally go too long, but there should be no more misses. Long dwell will be fixed next beta
3) Fix for people running too rich after upgrading from beta6. I was squirting fuel 2x too often on some configurations.
4) Fix spark-cut revlimiter in dizzy mode
5) Fix MAP accel indicator (really just remove it and rename the TPS one... the TPS one really represents both).
In the next beta I plan to work on the following:
1) .1% PID settings for PID closed loop idle speed.
2) Add support for stepper motor idle to PID closed loop idle speed
3) Finish fixing dizzy dwell
4) Finish fixing Neon mode.
5) Make sure oddfire dizzy works.
The beta is here:
http://www.msextra.com/ms2extra/files/b ... 070930.zip
cmcook
Re: MS2/Extra beta 10 (20070930)
Post by cmcook »
muythaibxr wrote:Fixes/Changes in this release include:
Is it possible to let us know what configurations are affected? I've got a reasonable table with beta7, I changed to alpha-n about the same time as beta7 so might have missed this problem. It would be nice to know if I need to change anything (ie req_fuel) when I change the firmware.
Thanks,
Chris
muythaibxr
I believe people with > 4 cylinders running 2 squirts alternating are affected.
There are probably other people affected too. I did not sit down and try to figure out all the affected configurations.
hassmaschine
Post by hassmaschine »
great! I'll give it a shot later tonite when I get home and see how it works.
easyBob2
Post by easyBob2 »
Great stuff! I'll try it out on Monday or Tuesday.
Thanks,
-Chris
95 Mazda MX6 LS ZE
MSII Extra; Wasted Spark Conversion
Paul260z
Post by Paul260z »
I think the spark cut rev limit in dizzy mode might also be affecting my lanch control. It works fine in the 1.0.2. ver. but when I switched to beta9 it no longer worked.
I will try beta 10 in the car tommorow after work and let ya know.
Thanks.
260Z Turbo MS2 Extra Beta9, Error* board, MSD 6AL
WWW.DFWDatsuns.com
cmcook
Post by cmcook »
muythaibxr wrote:I believe people with > 4 cylinders running 2 squirts alternating are affected.
Hopefully I'll be ok then - my VE numbers seemed about right. Thanks for all the hard work.
Cheers,
Chris
muythaibxr
oh yeah, and in the "todo," finish fixing dizzy dwell should be "finish fixing low-tooth-count-wheel dwell"
hassmaschine
tried it this afternoon - injector PW is fine, runs just like beta6. I think you licked that one.
thanks again! looking forward to the next update to the PWM idle code :D
Tjabo
Post by Tjabo »
Once the Neon mode has come along a little farther, I'm IN as a tester! (Or I'll jump in soon if you want)
I think I've pretty much got the MS1/Extra handled, and I've got an MS2 daughterboard sitting on the table! :D
Thanks for all of the continued hard work Ken, et al!
Thad (two Neons for the moment :| )
muythaibxr
Tjabo wrote:Once the Neon mode has come along a little farther, I'm IN as a tester! (Or I'll jump in soon if you want)
Don't forget James!
He made extended the wheel decoder to support uneven wheels, including the Neon!
Tjabo
Post by Tjabo »
Excellent point, Thanks James! ! ! ! ! :lol:
easyBob2
Post by easyBob2 »
muythaibxr wrote:oh yeah, and in the "todo," finish fixing dizzy dwell should be "finish fixing low-tooth-count-wheel dwell"
So you are saying that this won't help me with my 6-1 wheel/wasted spark setup? :(
-Chris
95 Mazda MX6 LS ZE
Paul260z
Post by Paul260z »
launch control is working in beta10.
WWW.DFWDatsuns.com
muythaibxr
-Chris
It will help you, you shouldn't have misses, but dwell A will go a little too long where it used to miss.
easyBob2
Post by easyBob2 »
Beta10 is working great for me. Ding dong the miss is gone!...Sorry, I've had that stuck in my head. :)
Still need to drive it around and datalog it a bit more to make sure nothing else pops up, but it's working great!
Now, about the PWM idle control frequency being to low.... :D
-Chris
95 Mazda MX6 LS ZE
muythaibxr
-Chris
I don't know that I'll be doing anything about that for 2.0, maybe for 2.1.
