Beta 9/ ls1 24-0 wheel, no fire
Well the setup is MSII beta 9 (beta20070905),
5.3l gen III chevy motor,
5volts to the crank and cam sensors brought in directly to Tsel for crank and js10 for the cam sensor with 1k resistors in parallel on both
Wasted spark with 8 CNP wired directly to leds (works for MS1extra) with a fourth led driver circuit created fire spark D
Spark A=led 14
spark B=led 16
spark C=led 15
Spark D=js11
Also have a tach out circuit with outout from cpu js0/iac1
I started with the msq that is loaded when the firmware was loaded followed the ls1 suggestions per the msii-extra documents.
THe problem is I'm getting no spark I dont see the leds flashing (i know it will be a small flashs but still visable an cranking speeds). I am however getting a RPM signal, so im pretty sure its a setting issue.
I know the harness is wired correctly because it will run with MS1-extra well with issues see here . http://www.msextra.com/viewtopic.php?t=26200
Any help would be great
Graham
Spark A=led 14
spark B=led 16
spark C=led 15
Spark D=js11
Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
89 SWB chevy truck successfully squirted
Black 03 Cobra
68 c-code mustang
Black 03 Cobra
68 c-code mustang
Please post an MSQ. I can test this with the JimStim on the bench.
Good find. It is broken. Don't know why yet.
I'll look at this at some point this week.
If you have time, try older beta/alpha releases. I'm sure I've tested this mode out before and am very suprised that we broke it, but we did.
At what point do the inputs and outputs change. I have some spare time just need to know when i need to break out the soldering iron.
Graham
Graham
Black 03 Cobra
68 c-code mustang
Black 03 Cobra
68 c-code mustang
all version 2 betas are the current wiring, and alphas for v2 from quite a long time ago. i've been out of nz for 4 months, and i was using the alpha from around then. hope that helps you.
fred.
fred.
ms2,v3,cop,innovate,mazda fe3/fe-dohc 2l 4cyl with stock 10:1 pistons,4 stock coils,4 stock ignitors,rx7 550cc injectors maxed@6600rpm&17psi,custom everything,holset he351cw turbo,44mm ext gate,nis gtr bovs,nis gtr intercooler,70mm lexus throttle,chinese fpr,10may v2 ms2e alpha code
also, i think in the manual, in the pinout, it says the dates, but not sure on that.
OK, I tested it out and found a one line code bug. I believe I've fixed it and will get another beta out once Ken has had a quick look at the code.
Did you get to try the latest betas to see if this works for you?
Sorry havent posted yet... However it will fire my coils now but having a low rpm.... ummmm miss. the rpm will totaly drop out. its random and only really happens when rpm is below 1500. One thing I have noticed is it will say "NOT SYNCED" In bottom right corner of mega tune when I experence the cut out. Will get a data log and post but wont be till late this week befor I have some time.
James thatnks for getting the beta fix out so quick. Once again you guys rock..
Graham
Graham
Black 03 Cobra
68 c-code mustang
Black 03 Cobra
68 c-code mustang
Have you looked into the wiring suggestions from "mobythevan" and "davew" ? They had to make a few small changes to get MS1/Extra work correctly with the LS1 sensors. Their changes should be applied to get MS2/Extra to behave.
I have done as they suggested and ended up using the opto-isolator as per the ms2 document. I have ms1 extra running the engine. It runs pretty good except for some upper rpm misfire. Im getting some noise in my crank signal. when I put plug in the ms2 computer (swapping the whole ecu not just the chip. I'm getting the rpm cut out as described before.
Graham
Graham
Black 03 Cobra
68 c-code mustang
Black 03 Cobra
68 c-code mustang
I'll have another look on the stim later this week. A datalog might help me diagnose what is going on. The MS2/Extra code WILL be made to work, as I intend to run it myself.
I'm using the following trigger wheel settings to test:
wheel arrangement: Dual wheel
teeth: 24
angle: (any)
Wheel speed: crank wheel
Second trigger active on: rising and falling
every rotation of: crank (new setting)
teeth: 24
angle: (any)
