neon.. MS1 or MS2?
neon.. MS1 or MS2?
i have a 2.4 swapped into my neon. and i have MS wired up and i have both MS2 and MS1 and i was wondering if i should just set up the MS1 cause the code works.. or use the MS2 let me know what you think. thanks
Given that there are some known issue with MS2 Neon code at the moment and you already have an MS1 I would suggest you use that. The spark wiring is the same for both codes so swapping should be relatively simple once we've got the MS2 issues nailed down.
