Has the signature PIP (v8) been put into the code? I read a couple posts where you had plain old TFI done, but were (possibly) working on the signature signal type.
If code is there, has anyone tested it?
Have a Ford with MS2 2.6 code that I would like to try MS2-E on, but I do not want to be alpha tester. A freshly converted carbureted car and being alpha tester is asking for trouble!
TFI Ignition Signature PIP
TFI can be used the same as a regular dizzy by triggering off a single edge.
The signature PIP might be adding too much complexity as the hall sensor apparently triggers differently depending on temperature ?!
Well I didnt see it in the ignition options, and I thought you were going to at some point possibly do both edge trigger instead of just simple and rising edge.
I will try rising edge and let you know what happens.
p.s. I know I always spell wheather wrong wheather or not the outside weather. Sorry for being silly, it is the little, red, happy sinus meds.
The reason for probably abandoning the both edges is because due to a Ford document the hall sensor responds differently depending on the temperature. Without some correction in there this would impact timing accuracy.
