Ken et al,
We have talked about this. Engine Saab 2L, 16V, 90mm x 78 mm stroke, Bosch 431 injectors (red top, HiZ, 334 cc?), Mitsu TE05 turbo, iron block, AL head 20070905 version of MS2/E.
I get smooth as silk idle with 1 squirt simultaneous. I have not yet modified my harness for alternating, so all I can test is simultaneous. With 2 simultaneous, I *should* be able to get decent PW control at idle with MS2/E, but I get wavering AFR and a noticeably lumpy idle. I attach the MSQ as well as 2 logs. The first log is just to show the warmup and how it idles nicely, but goes rich when running. It was n the drive home, but there are times I was not idling.... I just love Chicago traffic. The second is with 2 squirts to show the difference to 1 squirt and the wavering idle speed as wella s teh wavering AFR. I just do not get why 2 squirts is worse. Is there something I can try?
KeithG
http://ys3al35l.googlepages.com/ms2_11_eae3.msq
http://ys3al35l.googlepages.com/datalog200710171908.xls
http://ys3al35l.googlepages.com/datalog200710171920.xls
1 squirt better than 2 squirts and WUE issue
Opening time is pretty close as average AFR remains pretty close to the same with 2 squirts vs 1.
Battery correction... I played with it and saw no change. I am at 0.1 now and have tried 0.05 and 1.5 and it appeared to be no change. Does this require a power cycle to verify? With the 2 vs 1, I am thinking more of a mechanical issue than electronic, but am asking for things to look at.
As for the WUE issue, I am wondering if this is just my car/engine or what. I was teh same thing with MS1/E.
KeithG
KeithG
Injector opening time and voltage correction?
This is why I said your engine is weird. I've never seen an engine that likes 1 squirt simultaneous better than 2. I'd think that throttle response would suck with that setting too, but you seem to have better response with that setting.
I think I remember you saying that with 2 squirts, the AFR wavers even with EAE off so there's definitely something odd going on with your engine that doesn't happen to most people.
My engine also varies AFR at idle. I've tested injector opening time, and played with batt volt correction that helped a bit, but increaaing bat corr lag time helped out the most. My AFR is very good at 1 squirt simo, but 2 simo bumps my injector PW to a very low value, which ms likes to chnage alot, I think if it could just hold my PW to a constant number at idle things would be much better.
BTW... I have 740cc injectors on a 2.4 liter 4cyl.
The MAP sampling stuff should've helped you a lot. You could also use the EAE lag compensation feature to help give you good response but run less squirts at other times.
With injectors that large on that size engine, I suppose I'm not too surprised that it wants to fluctuate a bit.
However, I've found that messing with timing can help too... like if it's running too strong, sometimes that'll cause fluctuations that can be reduced by reducing the timing a bit.
I did that on the corolla and ended up with an idle pulse-width that doesn't move, even with EAE enabled.
