Any reason this launch circuit won't work with MS2?
(Runs on MS2 and Microsquirt)
Jon k
Post by Jon k »
Except go to JS5 instead of the MS1 default?
1992 BMW 525i M50 Non Vanos 24v Turbocharged
Stock COP Wasted Spark
MS2/E v3
rabiddeity
Post by rabiddeity »
That should work OK. I'd add a small capacitor across the switch leads (maybe 10nF-100nF), this will keep the switch from "bouncing" when it opens and closes, and cut down on noise transients too. Put the capacitor as close to the MS-II as you can; between JS5 and ground inside the MS case would be ideal.
