MS2/Extra 2.0 beta 14 (20071020)
It is certainly an error! I'll take a look.woh wrote:in file megasquirt-ii.ini.ms2extra under [Output Channels]; variable CheckSum and adc6 have the same memory location (141). Is that a problem? It is for documentation purposes.
Yes, it has done for quite a while.Philip Lochner wrote:Does MS2/Extra support Dual WBO and Cont Baro simultaneously yet?
That is very good news, I have to try it! Please could you just tell me where I would find the instructions as to how to wire it all - I've looked but I am blond.jsmcortina wrote:Yes, it has done for quite a while.Philip Lochner wrote:Does MS2/Extra support Dual WBO and Cont Baro simultaneously yet?
Kind regards
Philip
Philip
I've been updating the documentation for RS232 and ran across these. Not sure if these are bugs;
1. When I get a table (e.g.VE1) using the 'r' command no data is returned (0 bytes) when I first go to a new page. After the first time it always works even if the table changes (but not the page). Is that a bug? Or am I expected to add a delay after the first three bytes of the command every time I change the page? It works fine with a delay after the first three bytes. I'd like to see the firmware keep track of page changes and add a delay. That would make the command definition much cleaner.
2. command "c" returns a single byte. It appears to be the 'high' byte of the variable 'seconds'. Is that as it should be? I expected the two byte variable 'seconds' or maybe a single byte that counts in seconds.
3. Should there be a "C" (capitalized) command?
4. The "A'" command works just fine returning 152 bytes. The "a\x00\x06" command returns 113 bytes. Does MS2/Exta support this 'a' command as an alternative to the "A" command? Or should I delete this in the documentation as an alternative to the "A" command.
Could you post an annotated comm.log of what you describe.woh wrote:I've been updating the documentation for RS232 and ran across these. Not sure if these are bugs;
This is not present in any MS2 code. "C" only exists on MS1. We followed suit.2. command "c" returns a single byte. It appears to be the 'high' byte of the variable 'seconds'. Is that as it should be? I expected the two byte variable 'seconds' or maybe a single byte that counts in seconds.
The "a\x00\x06" command is preserved in a failed attempt to support MV2.4. The "A'" command works just fine returning 152 bytes. The "a\x00\x06" command returns 113 bytes. Does MS2/Exta support this 'a' command as an alternative to the "A" command? Or should I delete this in the documentation as an alternative to the "A" command.
Hi guys.
Havent posted in a while, been busy with other thing, didnt really had time to play with my car or ms for tha matter.
anyways, did this AE feature made it yet to the code ? the one that shots extra squirts during ae, or rather for the durations of AE it changes to more squirts per cycle and then returns to what it was set for normal running.
thanks,
Mops.
P.S. with shame I admit that i'm still running B&G 2.687t5 code in my car, for like last 6 months, but i definitely wast to try out ms2/x asap. I'll be rebuilding engine soon aswell and got all sorts of new goodies to put on
thanks,
Mops.
BMW, 1985, E30, 325i, 2-door, 5spd. Lots of custom work. Turbo build in progress: http://www.e30tech.com/forum/showthread.php?t=55733
I was experimenting with 6 squirts per cycle on my straight 6 the other day. In order to get it to idle and even show an AFR I had to set my req_fuel as low ass possible and my VE at idle from 45 to 8!!! Otherwise it was way way too rich.
Is this a bug in the firmware or am I not setting something up correctly. I am using brand new bosch 24# injectors.
Based on my understanding, what you found is to be expected. Consider that the same amount of fuel must now be injected using 6 squirts as what previously was done most likely with 2. This means that the pw calculation should yield much smaller results, achieved by setting your req_fuel low and VE low.M52 POWER! wrote:I was experimenting with 6 squirts per cycle on my straight 6 the other day. In order to get it to idle and even show an AFR I had to set my req_fuel as low ass possible and my VE at idle from 45 to 8!!! Otherwise it was way way too rich.
But why would you want 6 squirts per cycle anyway, other than fooling around?
Last edited by Philip Lochner on Wed Oct 31, 2007 5:47 am, edited 1 time in total.
Kind regards
Philip
Philip
Sometimes I regret opening my mouth!Philip Lochner wrote:Based on my understanding, what you found is to be expected. Consider that the same amount of fuel must now be injected using 6 squirts as what previously was done most likely with 2. This means that the pw calculation should yield much smaller results, achieved by setting your req_fuel low and VE low.
6040solder is right, if your opening time is close to actual, you should have little difference between eg 6 squirts and 2 squirts. However, I find it hard to understand how opening time alone could account for such drastic differences in your fuelling parameters.
Kind regards
Philip
Philip
say you need 1ms opening time, and you have it tuned at 0.8ms opening time, your overall pulsewidth is 2ms to get your chosen afr with the incorrect opening time, so your actual fuel flow is for 1ms but the ecu thinks its 1.2ms
you are on one squirt
you change to 2 squirts and it gives each of them 0.6ms of squirt and 0.8 of opening time. this is 1.4 total each. because its actually supposed to be 1ms opening, you end up with only 0.4ms of fuel flow per squirt, and 0.8 total.
now change to four squirts and you get 1.2/4 = 0.3ms per event on top of the 0.8ms opening time minus the 1.0 actual opening and you are left with only 0.4ms total fuel flow.
in effect your initial tune was wrong because the opening time was wrong, but it worked until you changed squirts and ended up with 66% of the fuel, and then 33% of the fuel. obviously if you have it too small the opposite will occur.
i hope that helps :-)
Which firmware? Alternating or simultaneous?M52 POWER! wrote:I was experimenting with 6 squirts per cycle on my straight 6 the other day. In order to get it to idle and even show an AFR I had to set my req_fuel as low ass possible and my VE at idle from 45 to 8!!! Otherwise it was way way too rich.
I've switched between all of the various numbers of squirts with no problem so there might be something else going on.
That feature has been in and tested for quite some time now. So yes it's inmops wrote: anyways, did this AE feature made it yet to the code ? the one that shots extra squirts during ae, or rather for the durations of AE it changes to more squirts per cycle and then returns to what it was set for normal running.
Better throttle response is the main reason to do this.Philip Lochner wrote: But why would you want 6 squirts per cycle anyway, other than fooling around?
I run 4 squirts alternating or 2 squirts simultaneous (with EAE lag compensation going to 4 squirts during accel) because the throttle response was *much* better that way. This will hold us over at least until we can do sequential injection... which will give the best throttle response (and is the best reason for going to sequential).
IF your injectors are too big or too small then you won't be able to just go to the maximum number of squirts for your engine so I added the lag compensation feature, which automatically goes to the maximum number of squirts for your engine when tpsdot or mapdot go over a certain threshold, then goes back to the normal number of squirts otherwise.
I also have some other features in mind to help throttle response, such as if you're mid-squirt when an accel event occurs, extend that squirt to the new value so that cylinders on those injectors will get close to the right amount of fuel that much sooner. I also plan on doing some MAP prediction using manifold volume, engine volume and throttle position along with an Alpha-N table (tuned properly). This should also help throttle response on certain engines.
OK, understood.This is not present in any MS2 code. "C" only exists on MS1. We followed suit.
Yes, I will when I get back home. Likely on Friday.Could you post an annotated comm.log of what you describe.
The basic problem is that after the first three bytes are sent the firmware does not appear to implement the remaining command if a new page is required. Two fixes on my end are adding a delay in the middle of the command or repeatedly sending the complete command until data is received.
Will the "a\x00\x06" command survive long term? If it survives, will it be the same as the "A" command long term or only return a limited number of bytes?The "a\x00\x06" command is preserved in a failed attempt to support MV2.
If it is a failed attempt to support MV2, How about deleting it so there is no confusion with MS2std, or just making it the same as "A" (ie the variables).
