Thanks Enrico,
It is always nice to know someone else uses VB
MS2/Extra 2.0 beta 14 (20071020)
Yes, there are several workarounds.jsmcortina wrote:That makes sense. When the page changes the code copies the flash data into ram. This takes a finite time.
I am assuming that with 115200 comms the next character may get dropped in this time period.
Megatune implements a delay between bytes.
I think it would be simpler and easier for the unitiated if this worked without the user putting in the delay. Any chance of you or Ken adding a 'fix'.
The easiest fix would be to change the baud rate to 300 baud.woh wrote:I think it would be simpler and easier for the unitiated if this worked without the user putting in the delay. Any chance of you or Ken adding a 'fix'.
James, I think ye doest jest. 300 baud! Not good!jsmcortina wrote:The easiest fix would be to change the baud rate to 300 baud.
So do I document it as is?
I suspect it is the other commands as well. Do you know if this applies to all commands that have a page parameter, or just the "r" command?
Yes, I was joking. 300 baud would be painfully slow.
Because the code must copy 1k of data from flash to ram there will always be a delay. This cannot be changed on the current chip. The tuning software must have a pause in there.
Unaclocker, you can currently change the baud rate - there's a baud rate menu under Communications. Once you've changed this you'll almost certainly need to use the boot jumper next time you re-flash.
