MS2/Extra 2.0 beta 15 (20071104)
Had a go and loaded up beta 15. All seems ok but I need help with the settings for closed loop stepper control.
Simply, what do each of the settings do and mean? And what on earth is PID?
Ive been able to get it working to some extent but its not great. The RPM rises suddenly if the RPM drops below the RPM target curve.
But otherwise great release. Keep up the good work fellas.
Andy
Andy
1991 Discovery. 5.7 SBC TPi, MS2extra, EDIS, LPG.
1985 Range Rover Landranger Kit. 4.6 Rover. To be MS'd for LPG.
1993 Ducati 888
1992 Ducati 900SS
1993 Ducati 888
1992 Ducati 900SS
I'll be documenting the settings soon.
The PID acronym stands for Proportional-Integral-Differential, it's a type of control loop that's used to take feedback from a system, and use it to control the system in a desired manner.
Generally you want P to be high, as that's the "immediate" correction.
So if the target rpm is 800 rpm, and you're at 1600, and you have the P value set at 50, it'll change the valve position to try to bring RPM down by 400 rpms.
I is the integral correction, and is used to cause small errors to build up and cause a change... so if you have your P term set low, and that gets you to around 900 rpms with a target of 800, eventually, each time the loop runs, that 100 rpm error will build up. With an I term set, that will eventually build up enough to cause a small change.
D is used to slow down the correction as it gets closer to the target, but having a D that's too high can also cause instability.
A full explanation can be found on wikipedia.
Be sure to use the firmware downloader batch file supplied with the beta. Do not attempt to load with the normal firmware downloader.max@zl2max.gen.nz wrote:Hi Guys
Anyway grabbed this beta, but couldn't get it in,
tested the code today with a iac for the first time and its working ok i have a problem were sometines the steps stay at max(for a second ) and the rpm drops to about 500rpm but i think its more the pid setings
since its my first time using the code it needs more tuning to be perfect
but its alot of a improvment since i wasnt using any idle control
Seems to be that IAC stays always on on that beta, as is gets hot within 10 minutes of use. In fact, it stays powered even when i select on/off valve or PWM valve from the idle control menu and configurator. I can also verify this from the Tuning-realtime display, where Voltage varies from 9 to 12V all the time (using a 12V 1A AC powerpack).
I'll have to flashback to an earlier beta, to verify this.
OK, sorted that out....
Grabbed the new version and used the command line option and jumperless
stuff now loaded and running megatune, so off to look see
So even the new ( version 200 ) will not handle these in the graphical
interface ???
Max
jsmcortina wrote:
Max Wheatley
max@zl2max.gen.nz
________________________________________________________________________
Delivered using the Free Personal Edition of Mailtraq (www.mailtraq.com)
interface ???
Max
jsmcortina wrote:
--*max@zl2max.gen.nz wrote:*
Hi Guys
This pÄost is at:
http://www.msextra.com/viewtopic.php?p=173399#173399
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.503 / Virus Database: 269.15.28/1123 - Release Date: 11/10/2007 3:47 PM
Max Wheatley
max@zl2max.gen.nz
RangeRover with MSII V3
Ken,
Hey, I tried semi sequential with my setup this morning and it ran *very* rich. I had to keep backing off ReqFuel to keep it from dying at idle (AFR<11) When I turn off semi sequential, it runs normally. This behavior is with 2 squirts simultaneous. I did not experiment with 1 squirt simultaneous.
KeithG
KeithG
This sounds a bit like the problem I have. Never got semi-sequential to work, so I have just been waiting a while. I use 1 squirt simultaneous ore 2 squirts alternating. I have wired my injectors as described in other posts. Think the last time I tried semi-seq. was with beta 14 but my engine just stalls (too rich I think). I am not able to use any more squirts as my idle pw is 1,2 ms. I asked about this before, but I do not think I got an answer…am I supposed to use 1 squirt simultaneous when I turn on semi-seq?
Vegard
Vegard
Audi 80Q 2,0 20V Turbo 630cc AEB/ABA/ABF
MS-II V3 MT2.25 MS2 Extra 2.0.1 VAG/Bosch VR 60-2 Waste spark PWM-idle
So, with 4 cyl COP, the valid values are 1,2,3,4 and for 4 cyl wasted spark, the valid entries are 1,2?
KeithG
On Nov 14, 2007 3:09 PM, muythaibxr wrote:
KeithG
Basically you just specify a trigger number...
On a 4 cyl COP there are 4 triggers, wasted spark, there are 2, etc...
It will start the sequence on that trigger.
