Code flash issues. Stack pointer out of range, e=0xE3
- 460stang
Trying to upgrade from MS2 V 2.36. I am using a 14 volt battery with the stim and an old 900 MHZ desktop computer with XP.
I followed the instructions remove the boot jumper and powering up and down at the correct times. I tried several times on com ports 1 and 2. I also changed the com port settings in windows to 115200. This is the best I can get. Please help this car was running before I decided it was time for an upgrade.
Press any key to continue . . .
ms2dl.exe -c2 bootstrap.s19
MegaSquirt Download 1.05
Reading bootstrap.s19:
bootstrap.s19
Detected MS-II (HCS12) code.
Entry point: 0xc000
Code range : 0x4000-0xfff0
File read successfully.
Opened comm port 2 at 115200.
Erasing main FLASH:
Erased.
Writing:
Write complete, 213 records, 3392 bytes.
Verifying:
Verification succeeded, 213 records total (8 skipped).
Bootstrap loaded...
5. Turn off Megasquirt
6. Remove Boot jumper
7. Turn on Megasquirt
ms2dl.exe -c2 ms2_extra.s19
Reading ms2_extra.s19:
ms2_extra.s19
Entry point: 0xc000
Code range : 0x4000-0x3dbcd0
Erasing main FLASH:
Erased.
Writing:
Setting page register 0x3b:
Page set.
Erasing page 0x3b:
Erased.
ERROR: Stack pointer out of range, e=0xE3
bootstrap.s19
Entry point: 0xc000
Erasing main FLASH:
Erased.
Writing:
Verifying:
Bootstrap loaded...
ms2_extra.s19
Entry point: 0xc000
Erasing main FLASH:
Erased.
Writing:
Page set.
Erasing page 0x3b:
Erased.
88 Stang 7.7L Twin Holset Turbos 95# injectors MS2extra
93 Ranger Splash 2.3L turbo 560 hp 33 psi MSII EXTRA 3.0.3,
81 5.0L TT mustang 440hp 10 psi MSextra,
93 Honda Civic B18 MSII Extra 2.0.
90 S10 350 twin turbo MSII
88 350 Procharged camaro MSII extra.
92 Toyota truck 5.0 swap, rear turbo. MSII
- 460stang
I did use the "download-MS2-firmware" that came with the beta zip. It was created November 22, 2007, 10:44:02 AM.
I also have all three LED's on the MS stuck on now when I power up.
EDIT.
After I tried again I still got an error at the same spot but at least all 3 LED's are not stuck on now.
EDIT.
- 460stang
I kept trying and finally it worked.
The last try that worked I went throught the whole thing again as if I had MS2 code and it failed at the same point, then I went through as if I had Extra code in (no boot jumper) and it worked.
I had tried this exact sequence before already. With no joy.
- 460stang
I created a complete MSQ on my desktop then moved it to my laptop and when I tried to burn it on the MS it would act up giving me looping too low voltage for burn readings. I checked voltage (the car would still crank just fine). I tried several times without success. I did notice before I tried to burn the Megatune would show normal settings and numbers. Not sure what that was about but the only way I could get out of it was to reflash the .s19 file and then make a new msq on the laptop with the MS still connected and powered up and then it worked fine.
- 460stang
Just one thing I remembered. Somewhere near the end of trying to get the code to flash I set my com port buffers down to 1. It did not work right after that, but it did not work at all before that.
I am having the exact same problem i have loaded the extra 1.0.2 just fine but if i try to load the beta 2.0 it keeps getting stuck at the same address in the code and wont go no farther i have tried with three different computers and they all do the same thing. But i can reload the 1.0.2 in no problems at all.
This is the message i get every time and the progress bar wont go any farther than 40%
Erasing main FLASH:
Erased.
Writing:
Page set.
Erasing page 0x3b:
Erased.
Erasing main FLASH:
Erased.
Writing:
Page set.
Erasing page 0x3b:
Erased.
There is no progress bar in the correct downloader....
You absolutely MUST use the download-ms2-firmware batch file provided.
The chip on MS2 is actually 128k even though it is badged 64k. Our code makes use of it all, the standard monitor in the chip is only designed to work with the 64k so it doesn't work.
Ok i used the download batch file just like i use for loading the MS1 extra files only the one i used came in the MS2 2.0 folder and i get the same response it always stops and says.
And yes it dosent have the status bar just the dos screen.
Then i reload the release code 1.0.2 and it does fine loading it with the MSII Embedded code update utility.
Thanks for the help im kinda lost this is my first MS2 chip so i know its something im not doing right.
Also.. one gotcha that I've found that isn't documented anywhere - on some computers (like my dell inspiron) having the serial cable connected (without MT running) while powering on the MS will actually cause the MS to think that the boot jumper is connected, even though it isn't. When the MS goes into boot jumper mode, whether using the jumper or because of the cable bug, all 3 leds will flash momentarily.
What this also means is that if you have your computer powered up while connected to the MS and then you try starting your car, it won't work unless MT is running (or the cable is disconnected). I've talked to bruce and james or ken about this and it's a bug on the chip, and something that can't be fixed in the bootloader firmware...
Mike
Mike
Try using the batch file again, but do it as if you're switching from the standard firmware... meaning use the boot jumper.turbo355 wrote:Ok i used the download batch file just like i use for loading the MS1 extra files only the one i used came in the MS2 2.0 folder and i get the same response it always stops and says.
In the past, when I've had trouble flashing, to retry flashing, I have no choice but to go all the way back to the boot jumper technique. Like it has seriously hosed something. I've gotten a new laptop recently, but haven't had to flash a new firmware with it yet. I really suggest trying to get another computer just for the flash, get it done and you won't need to worry about it for awhile again.
Brian
'84 Dodge Rampage
'84 Dodge Rampage
