Using the built-in PWM module on the S12C
Other than the fact that you might have proven software PWM code, any limitation on using the hardware PWM instead? Just trying gauge the flexibility of the S12C chip on a 48pin setup
Hardware PWM is nice.
Well, you're limited to the bus clock scalers, and with the 48 pin C64, PWM will go thru the first 5 pins of the timer channels, plus Port P5 which is currently used by the bootloader jumper. That's 8 bit PWM - go 16 bit, you're left with P5, T3 and T1 as PWM. Not as flexible, but should be a lot less work.
The firmware as its written for MS2, how extensive it would be to move the pins around (like moving the triggers to a different Timer port to free up the PWM ports)? I seriously think that we should look at a variant of MicroSquirt, just re-arrange the pins, and add the extra circuits. Now of course, I can't do that....
Because the timer input capture pins share the same pin as PWM you are somewhat scuppered. If you move to a larger pinout version of the same family you can access the PWM and IOC pins at the same time.
My thoughts follow: you can selectively route the pins to either a timer or the PWM, and in 16 bit mode, you can only have 3 PWM output anyway (T1, T3, P5). Currently the bootloader jumper occupies P5 (which can be configured as GPIO or PWM), while the rest share pins with the timer. I guess it all depends on how many PWM output we want to provide (Idle & Boost Control in the current feature set) - by moving the triggers and injectors to the lower priority timers, you can now have a choice. The minimum configuration for timer usage is 2 injector channels and 1 trigger, and for a typical 4 cylinder sequential setup requires 2 triggers + 4 injector channels you can still have up 3 PWM output.
The GPIO board is almost perfect for MS2/Extra if we can find out how to make some of those VB921 circuits drive injectors instead of ignition
Unless you change the bootloader, you can't use P5. That's not a big change to do in the bootloader code but you need a BDM to change the code on the chip.
If you use external injector drivers such as my p&h board, you can just remove the VB921 and use the cpu signal to drive the injector driver.
