I run both LPG and petrol on my car. The reason for doing this is that petrol is very expensive in Europe and LPG is not.
LPG is Liquid Propane Gas. But in The Neterlands it is 60% Butane and 40% propane or other mixes.
Th problem is: LPG will be vapourized and is injected in vapour form. When cold it has a smaller volume and the need for LPG is less. (80% or less at cold start).
With the VE-Table switch the injectors will also switch.
For different fuels you would need different startup parameters. Would it be hard to duplicate the startup parameters and get them to work with the selected VE table ?
A checkbox with "use different startup parameters for VE table 2" ?
Request for switching tables - switching start/ASE prefs
Volvo 242GT Turbo
MSII/Extra
Quad VB921 (True COP)
BiFeul trough switching tables (LPG / Petrol)
TechEdge 2E0 WBO2
MSII/Extra
TechEdge 2E0 WBO2
