Ok, see thread http://www.msextra.com/viewtopic.php?p=177993
This doesn't belong here I don't think.
MS2/Extra 2.0 beta 17 (20071227)
Do you remember what edits you made in regards to my findings?Gokart wrote:Try this newly arranged interface.
changes/enhancement:
1. addition of vac/boost indicator
2. edit to msoultan's findings
3. new interface layout
If many do like this arrangement, hope that James/Ken will implement it in the future releases.
thanks,
MIke
msoultan;
I thought that nobody seems to be interested since there are no feedback regarding that ini. The changes to your findings are found here:
http://www.msextra.com/viewtopic.php?p= ... ht=#175768
(4G63T - MSIIextra) (4G13 - MS3-beta testing)
I'd sure like to see a right-click-changable direction on the lambda/AFR bar on the bottom - i.e. more dots means rich. And of course, a WRITE ini function, so I can set up my guages how I like and have them be that way next time, instead of hand editing the ini every time.
2000 VVT Miata turbo, MS3Pro
You don't have to hand edit the ini every time. Create an INI file in the mtcfg directory for that particular car and put a line at the end of custom.ini to parse that ini file.
#include "your.ini"
Keep the quotes. The ini file merely has the edited lines from your last edited ini file WRT gages and such. Since these are read 'after' the stock ones, these are all that you will see.
KeithG
On Feb 4, 2008 7:01 PM, AbeFM wrote:
#include "your.ini"
KeithG
