Sync error on pretty vanilla ms2-e install
I don't know what's with me and sync errors....I upgraded from a working msns-e 029v install to ms2-e b18. I didn't re-wire my input trigger, so I'm using falling trigger instead of rising. It's a 60-2 wheel, and was running on the msns-e install with first trigger as tooth 6, return tooth 15 (6* cranking advance), with a trigger angle of 60*. So for ms2, trigger angle was set to 0, and first tooth was set to 96*. Something weird is happening with the sync while cranking, see the datalog attached. It's giving an odd repeating RPM pattern. In other words, it can't keep the sync, but it's seeing something. Is there a raw trigger table that I can look at like in msns-e? I never had an issue running msns-e all the way up to 7200rpm, so I don't think it's a hardware problem unless I'm missing something with how ms2 is reading teeth. Any tips?
edit:// sorry: 6 cylinder with wasted spark, LEDs output circuits driving OEM 3channel ignition modules, in pairs.
Ok, so provided that the sensor polarity is correct for the circuit it doesn't matter whether you use rising or falling so long as the other signal is the same and the setting is correct. Thats how i thought it worked. I thought you were saying that you could only use vrout, and never vrinv for some reason.
