More Precision in MAT and Coolant Maps?
What stops there from being more data points in the MAT correction map? I would like more than 6 points to be able to tune my MAT correction map precisely. I can get it sort of close +- 0.5 AFR with the current map, but I don't think 6 points is enough to tune temps from 20 degrees to 140 degrees. Could someone explain this to me?
The same goes with the warmup/coolant correction map. I don't use my warmup settings as only warmup. I have been using it as a full coolant correction map, and I would like to know what keeps us from being able to have more correction points.
If I had to guess it is to save memory space. I believe that the code interpolates the locations between points to smooth out the curve. That being the case there is less to store and will free up room for other features.
If that is the case there is probably no reason that it could not be done other than lack of storage on the chip.
Someone please correct me if I am wrong.
Cheers,
Rufus
Cheers,
Rufus
Is there any desire out there besides myself to get more points for finer adjustment of the MAT correction map? I understand interpolation and memory usage, but I personally believe its more important to have accurate fuel and spark control over extra features. I think the extra features are cool, but in my experience, MS still cannot replace a stock ECU in terms of accuracy and consistancy.
yes, possibly.Maddog6961 wrote:Is there any desire out there besides myself to get more points for finer adjustment of the MAT correction map? I understand interpolation and memory usage, but I personally believe its more important to have accurate fuel and spark control over extra features. I think the extra features are cool, but in my experience, MS still cannot replace a stock ECU in terms of accuracy and consistancy.
the right way to fix that is to have good sensor in good location. ask me how i know...
BMW, 1985, E30, 325i, 2-door, 5spd. Lots of custom work. Turbo build in progress: http://www.e30tech.com/forum/showthread.php?t=55733
close to the front of the car if possible such that ambient air flows across it on the outside.
this was a very common issue pre these tables existing at all.
in an NA engine, near the filter entrance would probably be pretty good, in a turbo vehicle in the pipe out of the intercooler as close to the cooler as possible. mines about 2" inside the front panel of the vehicle, i had no issues like that at all.
mops is correct there. the oems don't use them like we do.
consider how many cycles it takes to ingest that hot air and you'll see that its gone very quickly and doesn't matter.
if your plenum is pretty big, say 2l on a 2l engine, all that hot air and another litre down the intake tube is gone in 3 revs which with cranking at 180rpm is 1s. I believe there are settings to account for after/during start richness anyway, whereas a wrong reading while you are driving is impossible to deal with well given the tools you have.
So I still have varying idle AFRs after a warm startup. I moved my sensor way away from the engine to prevent heat soak but still after my intercooler. I'm not so sure that this is air temperature related after all.
After a warm startup, I will go lean until I have driven the car around for a bit, and then I can get back to my target AFRs. Any ideas here?
I may retract my statements...I think quite a bit of playing with BIN values and VE numbers has fixed my idle problems. I am suprised at the amount of VE change that can occur at low rpms and low map settings. My idle seems to be consistant now, but I will report back if I am having any additional problems.
On a hot restart, I was at a lightly higher map reading than normal (5 kpa or so) and I to increase my VE values a bit to compensate for that.
