MS2DL
muythaibxr wrote:That wasn't so much a port as it was a rewrite in C.
Just going by what you said in the file :-)muythaibxr wrote:/* This program is a VERY quick and dirty hack which will be cleaned up later
* I wrote it very quickly in order to be able to reflash the MS2 from linux, so
* things like comport speed, etc... are hardcoded
* and I'm using blocking I/O when non-blocking would be better, and
* I can get into situations that require the boot jumper on occasion
* This program is based on efahl's ms2dl C++ program, but ported to Linux. and
* rewritten in C.
* $Id: lin_ms2dl.c,v 1.3.2.1 2007/03/25 16:28:35 culverk Exp $
Attached for his/others reference.
Your efforts might be better spent learning how to use glade and helping design the front end for MTX ready for David to complete his ground up rework of the core components.UnaClocker wrote:Sweet.. Now if someone could port MegaTune to Linux.. hehe.. I'd love to be able to use Linux with my MSII..
MT is written in C++ using M$ Visual studio, I believe that it uses M$ libraries too, if thats the case you would basically need to rewrite all the GUI stuff and probably everything that interfaces with it. I could be a bit off the mark there.
Having said that, it already works pretty well with wine at least most of the time.
