MS2/Extra 2.0 beta 20 (20080127)
(Runs on MS2 and Microsquirt)
Post by jsmcortina »
Changes this release:
-fix dwell for oddfire distributor setup
-add capability for 5th and 6th spark outputs (ADC6, ADC7)
-more work on CAN pass-through
-add floodclear setting to menus (EDIT)
The beta can be found here:
http://www.msextra.com/ms2extra/files/b ... 080127.zip
As always, post to this thread with any problems.
6040solder
Re: MS2/Extra 2.0 beta 20 (20080127)
Post by 6040solder »
jsmcortina wrote:add capability for 5th and 6th spark outputs (ADC6, ADC7)
Awesome :-)
A lot of people will be happy to see that!
Great work as always.
mops
Post by mops »
jsmcortina wrote:Changes this release:
yes, yes, yes !!!!
where are the docs that document it ?
yes, COP, that's the last feature i wanted....
BMW, 1985, E30, 325i, 2-door, 5spd. Lots of custom work. Turbo build in progress: http://www.e30tech.com/forum/showthread.php?t=55733
JeroenBosma
Post by JeroenBosma »
How we found out something was not right with "Odd fire"....
We have a scope now and it looks ok !
Great work folks !
I guess this looks odd too...
http://nl.youtube.com/watch?v=_7zf_EY-ILY
http://nl.youtube.com/watch?v=d2qrDzCGG98
:shock:
Volvo 242GT Turbo
MSII/Extra
Quad VB921 (True COP)
BiFeul trough switching tables (LPG / Petrol)
TechEdge 2E0 WBO2
yes, yes, yes !!!!
Here they are:
Spark 5 = ADC6 = JS5
Spark 6 = ADC7 = JS4
Jon k
Post by Jon k »
Hey James I might be out of the loop but is there idle advance yet? I loved that feature in MS1
1992 BMW 525i M50 Non Vanos 24v Turbocharged
Stock COP Wasted Spark
MS2/E v3
JeroenBosma
I tried to trigger at the cranck gear that has 145 teeth. A second trigger will provide a single cam signal. But the code seems to reject this layout. It does make sense but it would make conversion more simple to accept random number teeth cranck-gears and a single cam trigger.
Could it be done ? I know this is the hard way but I do a lot of cars that are not designed to run on EFI. This would simplefy installation a lot. Simply drill a hole in the bellhousing, mount a VR sensor and install a hall sensor in the dizzy or at the cam.
Volvo 242GT Turbo
MSII/Extra
TechEdge 2E0 WBO2
muythaibxr
Post by muythaibxr »
Jon k wrote:Hey James I might be out of the loop but is there idle advance yet? I loved that feature in MS1
Idle advance has not been implemented.
It probably won't make it into 2.0, but I'll put it in one of the 2.0.x releases.
muythaibxr
JeroenBosma wrote:I tried to trigger at the cranck gear that has 145 teeth. A second trigger will provide a single cam signal. But the code seems to reject this layout. It does make sense but it would make conversion more simple to accept random number teeth cranck-gears and a single cam trigger.
We can't really do this... The number of teeth has to at least be close to dividing into 360 evenly (at least to a tenth of a degree). Even if we could handle the math, I'm not sure we could handle the interrupt load of that many teeth per rev.
JeroenBosma
I was afraid of that. What would you suggest if it was a straight six? only the camspeed can be used. I like to try to get it running as a twin 3 cilinder.
But appart from that, using the offset trigger together with a Honeywell 1GT01 sensor I have some weird RPM dropouts. Also I got some PW1 (PW2 is stable ?) dropouts. These are weird. Could it be (odd-fire)code related ? The Hall circuit is used and the signal cable is fully sheilded. I use raising edge on this one.
Volvo 242GT Turbo
MSII/Extra
TechEdge 2E0 WBO2
When the rpms drop to zero do you see the sync "light" in Megatune flicker?
sportage4x4
Post by sportage4x4 »
6 coil channels, now odd-fire with an even wheel and i'd be in heaven.
you guys get my first born.
1990 Mazda Miata: GM Gen3 V8 swap, 4.8L, custom cam, 2x GT2860R turbos, MS3 + MS3X.
2003 Kia Rio wagon: Mazda B6T/G25MR swap, Miata CAS, IHI RHF5 @ 2bar, LSx truck coils, P&H board, boost control.
sportage4x4 wrote:6 coil channels, now odd-fire with an even wheel and i'd be in heaven
I've not got to that one yet, although I have had some thoughts on it.
JeroenBosma
That would be superb. That would need a twin trigger though. A bit painfull that we'll have to take the engine out to mod the flywheel. A week work with all the hydraulics in the car.. Or could it be done with a 36-1 camwheel ?
I'll check on the sync once I work on the car again. Are the PW and the RPM related for this one you think ?
Volvo 242GT Turbo
MSII/Extra
TechEdge 2E0 WBO2
The "drop to zero" events are very likely a loss of sync. This could be noise or a code issue. Please persist with testing as I'd like it to work for you and others.
Maddog6961
Post by Maddog6961 »
I am having problems with table switching. When running table switching, I can't pull up the tune VE table 3 screen. It is grayed out like it isn't activated.
George Carstens
1984 BMW 533i turbo
MS II Extra Beta
http://www.wreckracing.com
Maddog6961
Can anyone else verify if this is an issue?
George Carstens
1984 BMW 533i turbo
MS II Extra Beta
Keithg
Post by Keithg »
Oh yeah, while we are here, can anyone determine if there is a problem with the MT gage with respect to LC-1 0-5V. There was a post in a different thread that this reads incorrectly. Anyone else verify this? Is it a MT problem? can we fix it through the ini, or is MT flawed? The work-a-round is to manually out in the data points for a generic sensor, according to one source.
Please let us know.
KeithG
muythaibxr
If there is a problem, it's most likely a problem in the curve that MT uploads to the ms2.
