MS2/Extra 2.0 beta 21 (20080210)
TPS lagfactor not working anymore?
It has bin a while since I have been using my car and played with Megasquirt. I was running perfect with beta 12. Upgraded to beta 17b to play with pwm-closedloop. When I started the engine it was running very rich because accel enrichments was turning on and of. My TPS have some noise and I have to use much lagfactor to make it stable. The quick solution then was to turn off TPS-accel enrichments. Today I upgraded to beta 21 but the problem is still there, jumpy TP and TPSdot and it does not seam to matter what lagfactor I use anymore. I will test some more tomorrow and try to make a log of my problem.
Vegard
Vegard
Audi 80Q 2,0 20V Turbo 630cc AEB/ABA/ABF
MS-II V3 MT2.25 MS2 Extra 2.0.1 VAG/Bosch VR 60-2 Waste spark PWM-idle
Sorry. Seams my TPS is playing with me again. I don’t think there is a problem with the TPSlagfactor. Tried a few older betacodes today, but my noise problem was still there no matter what factor I use. Maybe I will have to use a shielded cable for my TPS signal…
Beta 21 seams to work as it should on my simple Audi 1,8T with 60-2 trigger and waste spark.
Vegard
Vegard
Finally loaded this version. I was running a pre-version with the multiple PWM idle frequency selections.
All I can say is awesome. I am finally back with a drivable car that I can have valeted or loaned to my wife without fear of repercussions. I am running 100ms loop time and 30hz PWM frequency. It adjusts nicely to load. It is winter, now, and I am sure I will have to adjust the PID constants in summer as a tweak, but it is very nice with my Bosch 2 wire valve.
I noticed one thing with the pre-version that it would hold open the AIC valve every so often following a hard accel when throttle was dropped. It would adjust for this quickly. I will need to log this to be able to figure out exactly what is going on or even if it is apparent with the 2/10 version.
Thanks!
Keith
Thanks!
Keith
Ah, I'm going to try it myself, I'd read above that the code was "broken", but if not then it's on my list.
I've found out that the Miata uses a very high 488 Hz, which would be a 16 on your scale, but it's much quieter at least on 244.
2000 VVT Miata turbo, MS3Pro
Abe,
Keep in mind that the frequency is inversely proportional to the number of steps. I needed more steps to actually allow the PID controller to have enough 'room' to operate. This is truly a balancing act between number of steps and noise due to lower than desired frequency.
Hopefully, there will be a delicate hardware/software modification in the not too distant future to have true PWM control for the idle for those of us running Hi-Z injectors. That way you can have both higher freq and reasonable step size.
KeithG
KeithG
Ken,
There is something odd about the new idle code. It does not seem to be in the logic as that has not changed and it is predictable and acts normally. It acts normally in normal driving. It is just when throttle is dropped abruptly from a higher RPM and decent load. (hard accel then drop throttle at 4krpm or so.) RPMS hang and drop as though the AIC percentage was not at a value that the MT DC% shows. My guess would be that if the 'dashpot value' was 37%, it was probably at 50% or so when the idle control engages.
Traffic was terrible on Friday, so I was not able to get a log, but I really do not think that MT reflects this, best I was able to see on teh laptop real time. It should be apparent on an oscilloscope trace, though. I now have a jimstim and a spare MS2 board. As soon as I get the board modded, I'll be able to see what I can see on the bench, but I thought I'd mention it here, now.
most of the time, you would not notice this. But it can surprise you in some situations.
KeithG
KeithG
Could be, I guess. I'll have to see if I can log it on the car and see if I can get my MS2 chip set up on my bench as well.
KeithG
muythaibxr wrote:
KeithG
muythaibxr wrote:
I've tried to duplicate that on the bench with the scope and can't get it to do anything weird... I wonder if your valve is just getting stuck or something b/c of the low frequency (I've seen that happen).
