MS2/Extra 2.0 beta 21 (20080210)
New this Beta:
- Changed frequency selection code for PWM idle, new behavior is as such:
Valve Frequency is now a number... the actual frequency is 30.5 Hz * that number...
Frequency options now include:
Setting: 1, Frequency 30.5 Hz, Accuracy 0.4% duty
Setting: 2, Frequency 61 Hz, Accuracy 0.8% duty
Setting: 3, Frequency 91.5 Hz, Accuracy 1.2% duty
And so on up to a max of
Setting: 8, Frequency 244 Hz, Accuracy 3.2% duty.
These frequency options are available for warmup only, and for PWM closed loop
- Changed closed-loop idle so that it now has the ability to use the extra PWM resolution.
I was unable to find any changes from James this time, but if there are, he'll list them as well.
The closed-loop changes will probably break IAC closed loop, so that'll be fixed in the 2.0-RC1 release I plan on doing later this week.
This beta can be found here:
http://www.msextra.com/ms2extra/files/b ... 080210.zip
- 460stang
Excellent,
I hope to try some of these new frequency settings. Got a honda B18 with a cold air intake on it. The PWM idle motor is the loudest part of the car, so much so that the car is currrently nick named "HOOVER" for the vacuum cleaner sound that eminates from the intake.
88 Stang 7.7L Twin Holset Turbos 95# injectors MS2extra
93 Ranger Splash 2.3L turbo 560 hp 33 psi MSII EXTRA 3.0.3,
81 5.0L TT mustang 440hp 10 psi MSextra,
93 Honda Civic B18 MSII Extra 2.0.
90 S10 350 twin turbo MSII
88 350 Procharged camaro MSII extra.
92 Toyota truck 5.0 swap, rear turbo. MSII
- 460stang
If you are refering to the idle motor sound, I don't know what frequency Acura runs the idle motor at but it was quiet with the stock ECM. (Even with a cold air intake in place)muythaibxr wrote:Heh... was it like that even at 156 Hz or whatever it was before?
I would like to know what that frequency is and my wifes 93 Integra GSR is stock with B17 engine and factory ECM in place. I am going to have to scope it and see. Likely I will find that it is a frequency that will not allow resonable resolution within the confines of megasquirt.
Same with my miata, even all the way past the intercooler, turbo, 3" open exhaust and all that, the IAC is easily the loudest sound coming from the car near idle. I'll be glad to try it out.
Matt, do you know any way to either log faster, or extend burst mode past 1 second? I don't mind logging less data (I can with without 80-90% of the data sent) but I would like to get 100 hz recordings if possible.
2000 VVT Miata turbo, MS3Pro
I didn't log that through MegaTune - for checking stock IAC valves, we use an oscilloscope.AbeFM wrote:Same with my miata, even all the way past the intercooler, turbo, 3" open exhaust and all that, the IAC is easily the loudest sound coming from the car near idle. I'll be glad to try it out.
:~/EFI/ms2extra/ms2extra_beta20080105$ ls -n
total 776
-rwxr-xr-x 1 1000 1000 9390 2008-01-06 06:48 bootstrap.s19
drwxr-xr-x 2 1000 1000 4096 2008-01-24 04:25 bootstrap_src
-rwxr-xr-x 1 1000 1000 5175 2008-01-06 06:48 CHOICE.COM
-rwxr-xr-x 1 1000 1000 658 2008-01-06 06:48 copyini.bat
-rwxr-xr-x 1 1000 1000 4895 2008-01-06 06:48 download-MS2-firmware.bat
-rw-r----- 1 1000 1000 140240 2008-01-06 06:48 megasquirt-ii.ini.ms2extra
-rwxr-xr-x 1 1000 1000 212992 2008-01-06 06:48 ms2dl.exe
drwxr-xr-x 3 1000 1000 4096 2008-02-13 06:49 ms2extra
-rwxr-xr-x 1 1000 1000 190300 2008-01-06 06:48 ms2_extra.s19
-rwxr-xr-x 1 1000 1000 185574 2008-01-06 06:48 ms2_extra_us.s19
use that file to load the firmware. nothing else will work. only that file.
hope that helps :-)
total 776
hope that helps :-)
