Hello
Can somebody to explain how work (hardware) Launch and table switching?
I running ms2extra_2.0rc1_20080301, i use JP7 for the c. maps And JS5 for launch
I active the extra function on megatune but under tuning menu are only ve 1 end adv1, Try to give the signal but the engine run with the VE1 & ADV1...look on the forum ad i found something for the ini file( Tuning Table Switching Bug? ) then appear also ve3, but on test no change happens...
Is possible to check (on megatune) the status of I/O like on MS1, on the bottom red for input, nos, map.,launch... green FP, idle,output...
Is so hard to test something you can't see
any suggest are very appreciate!!!!
Nobody have test Table Switching & Launch Control?
