rpm drops to zero
rpm drops to zero
what can cause this ?
60-2 vr sensor
rc1 firmware
60-2 vr sensor
rc1 firmware
it looks like they are caused by iac moving
on other ocasions it always happens when the iac changes steps
i had to jumper resistors yesterday (the log is from monday)because the iac stoped to work after 5/6 min and it didnt work on moving only, im going to do a log with the iac moving only
is there any way to fix this if it happens on moving only ?
I'd think you're onto it then - make it move more and see if it gets worse, and unplug it and see if it gets better. If so, then you know it's electrical and what's causing it. That's how I found one of my problems....
2000 VVT Miata turbo, MS3Pro
