When the selectable 12x12 or 16x16 tables first went into the MSII-extra code, there was a problem with the changes to 16x16 tables in MLV not showing up after MegaTune burned them to the unit. The reason for this was that MLV doesn't change any form of underlying memory model, just the values in the MSQ itself. So, when you update a 16x16 table in MLV it would save the changes to the msq fine, but when you loaded in in MegaTune and told it to burn, this would happen:
- The new 16x16 table is burned to the unit
- The old unedited 12x12 table is burned to the unit
Essentially step 2 undid step 1, and left it appearing that changes to only part of the table would stick. The part beyond the 144 offset of the 12x12 table.
I put in a fix for this some time back, where mlv does go through and alter the 12x12 table so it would stick.
However, in the more recent beta 2.0 versions the addressing of the tables has changed. It used to be that all the tables started in the same place whether it was in 12x12 or 16x16 mode, if in 12x12 mode bytes 145-256 were just unused. Now if you are in 12x12 mode, the next table starts immediately after the end of the last table.
Old:
veTable1: 0-255
veTable1doz: 0-143
veTable2: 256-512
veTable2doz: 256-399
New:
veTable1: 0-255
veTable1doz: 0-143
veTable2: 256-512
veTable2doz: 144-287
Now with the new memory layout, it is certainly more efficient use while in 12x12 mode, but now veTable2doz overwrites veTable1 when loading and msq. veTable2 is overwritten in part by veTable2doz and veTable3doz ...
I'm sure I can come up with a work around for this, but it will take a bit of work and before I did it, I wanted to know:
Questions
- Are you able to actually use any of that regained memory due to supporting the 16x16 mode?
- Was this simply a cleanup rearrange thing, that didn't really matter?
12x12 and 16x16 table memory overlap
It is only if you are doing the entire msq. Exporting the VEX and importing it works fine and is the work around.
Some people do prefer to do the vex all the time for various reasons.
I wouldn't worry about corrupting any other settings though, That would be very low risk, and there haven't been any reports of that happening.
I had to change the memory locations because 12x12 was actually broken.
