This is a forum for discussing the development and testing of alpha MS2/Extra code.
Documentation
(Runs on MS2 and Microsquirt)
Moderators: jsmcortina , muythaibxr
volenv
Posts: 13 Joined: Mon Jan 01, 2007 11:40 am
Post
by volenv » Mon Mar 17, 2008 1:54 pm
Works fine for couple of launches, after that the software uses only the hard rew. limit from the flat shift settings. Any ideas?
Golf mk1 1.8 8v -turbocharged 22psi 312whp
MEAGASQUIRT efi
rabid
Posts: 303 Joined: Mon May 09, 2005 7:44 am
Post
by rabid » Fri Mar 21, 2008 8:31 pm
I might have run into this as well. It seemed like it wouldn't stop at the launch limit anymore.
rabid
Post
by rabid » Sat Mar 22, 2008 7:37 pm
n/m I just had the throttle limit set high. I like to set it really low because too high and the rpms are already too high before you get the throttle to the right spot.
volenv
Post
by volenv » Tue Mar 25, 2008 12:01 pm
I'll try that and post.
MEAGASQUIRT efi
volenv
Post
by volenv » Mon Mar 31, 2008 2:19 pm
No. Its not the problem. Getting back to extra1 with the same settings solved the strange behavior.
MEAGASQUIRT efi
