Launch/ flat shift problem
(Runs on MS2 and Microsquirt)
volenv
Post by volenv »
Works fine for couple of launches, after that the software uses only the hard rew. limit from the flat shift settings. Any ideas?
Golf mk1 1.8 8v -turbocharged 22psi 312whp
MEAGASQUIRT efi
rabid
Post by rabid »
I might have run into this as well. It seemed like it wouldn't stop at the launch limit anymore.
rabid
Post by rabid »
n/m I just had the throttle limit set high. I like to set it really low because too high and the rpms are already too high before you get the throttle to the right spot.
volenv
Post by volenv »
I'll try that and post.
MEAGASQUIRT efi
volenv
Post by volenv »
No. Its not the problem. Getting back to extra1 with the same settings solved the strange behavior.
MEAGASQUIRT efi
