Can we get the IAC output spun around to match IAC1a,b for JS0, JS1 and IAC2a,b for JS2, JS3..? and figure out why IAC2 won't work when using IAC1. It's weird.. The first stage of NOS works on IAC2 not IAC1. But in order to use IAC2 you have to enable IAC1 in MT which works untill you remove power from MS. Power MS back up, then I get config errors. Only way to reset is to disable IAC1, cycle power and all is good.
Goal is to have a single stage of NOS and run an electric fan off of other IAC port. Thanks, Ryan
I was using 10oct07 beta and loaded the 10feb08 to see if there was any change, but there wasn't
IAC bug when using NOS and other output. Betas..
