Hi.
I´m still using Beta 21 on my car. At high RPM I had some trouble with jitter of the map-signal. This influenced the EAE and made it even that worse that the car didn´t accellerate in a proper way (because MS was intermediate leaning out the engine). When switching back to standard AE this erratic behaviour went away.
To solve this problem I decided (for testing) to set the RPM-Correction curves for SOW and AW to "0" above some RPM-setpoint. When I did this, I noticed, that under some conditions when lifting the throttle, the Car ran really really lean (Lambda 2,33!) and it took several seconds until the MS went back into normal operation. I wondered about this, because when I set the RPM correction curve to "0", shouldn´t there be any EAE in this RPM range at all? Or am I still misundersanding something basic about how EAE works?
Regards,
Thomas
EAE RMP-Correction question
