I open megatune 2.25 P3 and apear one message.
My PC is b14 and the MSII firmware is b21.
The problem is the b21 firmware in advance spark table apear bad information or garbage and when intent rectify the table and write the MSII go offline mode.
Please help
What is the software for beta 20080210
You must install the megasquirt-ii.ini.ms2extra file that comes with the firmware use "copyini.bat" to do this.
Beta b21 is work but!!!!!
Thank for your help.
The other problem is when the advence timing pass over 60 degree the program work bad. Is a MSII, V3, 2008210 firmware
Why do you want more than 60 degrees advance?
Ok my MSII is mounted in Jeep 4.0L 2006, take 2 trigger sensor and wastepack.
COP mode the triggeroffset no funtion.
The first 15 degree with the timming light is in 30 deggre in the advance table.The other 15 for the vaccum advance and when put the other deggre for centrifugal advance pass the 60 deggre and the engine retard in sound but not in gauge timing, When pass the 60 deggre the engine work OK.
15 = 30 in the advance table
30 + 15 =45
45 +15 = 60 Fail
30 + 15 =45
45 +15 = 60 Fail
