90turbovan wrote:I have the older 3.0.3q and 3.0.3m working with this wheel on a Silverwing parallel twin. The patterns are the same, the trigger tooth numbers are just a little different. In the older codes, the crank and cam angles per tooth are incorrect but I was under the impression that they were only used for interrupt masking/noise rejection. In any case, it syncs with no issues and runs up to 10k. I did, however, have problems with noise on the crank sensor. The compression stroke slowed the wheel down enough that it registered multiple zero crossings on a few of the teeth. I used the trigger logger and noise filters to get rid of it and it works fine now. I also had the polarity set wrong once and it wouldn't rev past 4.5k without lots of sync loss. I don't have the msq with me but I could check all of my settings tomorrow if it'll help.
Compression seemed to change the cranking timing on my engine, I set the trigger angle with the plugs out and hoped that once it started it was going fast enough to smooth things out some.
Edit: I'm running uS too.
OB6D wrote:Anyways, there's a diff of 180º between offset +90 and -90, this should be easy to see with the naked eye. I don't trust that setting at all.
jsmcortina wrote:OB6D wrote:Anyways, there's a diff of 180º between offset +90 and -90, this should be easy to see with the naked eye. I don't trust that setting at all.
Only +/-20 deg of change is actually used.
Can you confirm with a strobe where it is actually firing and what offset you really need?
Try resetting your ReqFuel with the calculator, there have been a number of changes in the code relating to two cylinder engines so the resulting pulsewidth might be quite different now - compare your logs.
During crank is the engine keeping sync? Or is it losing and gaining sync? Did you get any sync-error logs? If so, please email them to me and hopefully I can advise what is happening.
The section I examined of the "cranking when warm" log you sent the other day looked just fine.
90turbovan wrote:This engine uses the same crank and cam wheels, its just even fire. All I do is change what tooth it considers TDC and remove the "Must have odd fire" config warning. Maybe odd fire is causing some problems?
90turbovan wrote:First one shows the noise I was seeing, really short pulses. Second one is with the period rejection filter enabled, no noise at all. MSQ is for 3.0.3r. This engine uses the same crank and cam wheels, its just even fire. All I do is change what tooth it considers TDC and remove the "Must have odd fire" config warning. Maybe odd fire is causing some problems?
I didn't have to change reqfuel, it fired right up.
jsmcortina wrote:I have tested this on the scope and I agree that the rpms displayed are half the actual. Working on it.
