MS2extra 3.1.1 anti lag code
Re: MS2extra 3.1.1 anti lag code
Could you please writte a roving idle version for us? ;) also it would be great to have flatshift on a different input pin and setup window...
I think it should be great if Baldur could port als code to the last version of the firmware, much has improved from 3.1.1.
anyway 10x Baldur for adding this feature to ms2!
Does anyone have working overrun fuel cut values which gives an acceptable idle with raised throttle stop Position?!
Honda CRX B16A1 Turbo | MS3 running | pre1.5.1 beta7 Firmware | 24/1 Dual Wheel | COP ignition | 725cc ID injectors
Can you add some kind of pasword protetion to the tune ? btw, it works great !
over run fuel cut ->onmrx79 wrote:Does anyone have working overrun fuel cut values which gives an acceptable idle with raised throttle stop Position?!
rpm greater than: 1300
kpa lower than: 100
tps lower than : 2%
coolant greater than: -40
after delay: 0
lumpy idle, sounds like you have 320 degrees cams but it works
Just use idle valves, if you are not in group N...
Agree on that!vlad_rally wrote:Can you add some kind of pasword protetion to the tune ? btw, it works great !
And roving idle please baldur!!
use the settings I've posted above, you'll get the roving idle, just play with those settings until it works best for your application
Can you make a quick vid of your engine idling please? exhaust sound...m3ltd0wn wrote:use the settings I've posted above, you'll get the roving idle, just play with those settings until it works best for your application
I'll do a short video this week
Please.include this Anti lag system on latest alpha code...!
MSnS'n'4G15
Waiting.for.the vid...m3ltd0wn wrote:I'll do a short video this week
Please include Baldur's Antilag code on latest aplha...!
MSnS'n'4G15
It would really help if you could ad some king of spark cut idle limiting, to run the antilag with the throttle partly oppened, and this to be ignored when the antilag is turned on. Is it posible?
Does overrun fuel cut turn off when als in on?m3ltd0wn wrote:I'll do a short video this week
baldur wrote:You'll have to refer to the 3.2.4 release notes for that info, I haven't a clue.
To achieve the hunting idle with overrun fuel cut, the settings should be something like this:
RPM greater than: 1300
KPA lower than: 110
TPS lower than: 10 (set this to 2% higher than TPS state when the throttle is at minimum)
Coolant greater than: -30
After delay: 0.0
Delay EGO: 0
Return fuel: 1250RPM
Does 'Overrun fuel cut' turn of when antilag is active ?
Yes, ORFC gets disabled when anti lag is switched on.
Baldur Gislason
Thanks a milion! i've used this code on numerous rally cars, but with throttle cickers, now im doinn a gr. n subaru, and i'm not allowed to ad any extra funcky hardware.baldur wrote:Yes, ORFC gets disabled when anti lag is switched on.
But but....the download link dosen't work
Hi Baldur, where you able to work any more on this?
